Road cassette for M...
[Closed] Road cassette for M8000 2x11
I currently run Shimano M8000 2x11 groupset with 11-42 cassette and 38-28 chainrings.
I would like to have smaller caps between top end sprockets(currently 11-13-15-17). So I think I need road cassette like 11-32 or 11-34 - they typically are 11-12-13-14 at the top end.
Question: which road cassette works with my current groupset? For example from Shimano or SRAM?
Posted : 06/09/2017 7:34 am
There's a new Ultegra 11-34 option which has the same base width as an 11 spd MTB/10 spd road cassette, so will work on an MTB freehub. In stock at Madison - part no CSHG800134.
Posted : 06/09/2017 7:39 am
No compatibility between shimano road and 11 speed mtb. Not sure about sram but I doubt it.
Posted : 06/09/2017 7:40 am
That's generally the case except with the new wide spread Ultegra mentioned above.
Posted : 06/09/2017 7:41 am
This is tricky because road cassettes are wider than MTB cassettes and won't fit on your freehub. MTB cassettes use the space created between the spokes and the large 40+ teeth cogs to accommodate the large sprockets; Road cassettes have a much smaller large sprocket so there is less room between the sprocket and the spokes.
I read that there is one 11 speed cassette in the newest Ultegra group that will fit on the narrower MTB freehub. Maybe 11-32.
Posted : 06/09/2017 7:56 am
Is my post invisible? ๐Ÿ˜‰
CSHG800134.
Ultegra level 11 spd 11-34 cassette that fits on an MTB freehub body as the last sprocket is dished as on 11-40/11-42/11-46 cassettes. Requires 10/11 speed spacer (supplied) to work on 11 spd road freehub.
Posted : 06/09/2017 7:59 am
CSHG800134.
U ok hun? ๐Ÿ˜‰
Im interested in that cassette but as I swap wheels it might cause me to have to adjust the mech a fair bit whenever I do
Posted : 06/09/2017 8:13 am
Apparently there's a new 11 speed Ultegra cassette in 11-34 that fits a 10 speed MTB freehub body. I think the part number is CSHG800134.
Posted : 06/09/2017 8:48 am
Jonnyboi - blind to smilies too? ๐Ÿ˜‰
Mister P - very good!
Posted : 06/09/2017 9:10 am
Nope, Hence the winky.
Anyhoo, before we disappear down the emoticon rabbit hole... are you by chance running this cassette at the moment?
Posted : 06/09/2017 9:16 am
Nope - just noted it with interest like you.
Shouldn't need more than a bit of b-tension adjustment between this and MTB spreads though, so don't see swapping being a big deal?
Posted : 06/09/2017 9:30 am
As mentioned above swapping should be fine in terms of shifting.
The spacing between sprockets is the same between road and mtb 11 spd; it's just the freehub width that changes (hence the spacer included with sillyoldman's ultegra cassette).
I run a sram 11-36 11spd road cassette on my mtb, but machine down the carrier of the larger sprockets so that it fits my mtb freehub.
If swapping between 11-34 and 11-42/46 then you might need to compromise on chain length along with adjusting b-tension?
Posted : 06/09/2017 10:34 am
Looks like the Ultegra 11-34 (part no as above ๐Ÿ™‚ ) won't do what you want. The smaller sprockets are the same as the XT 11-42 from 11 to 21.
Posted : 06/09/2017 10:37 am
Good spot! Hadn't clocked that....
Posted : 06/09/2017 11:08 am
sell some parts off and drop down to 10 speed XT with 11-32 instead? ๐Ÿ™‚
You are only losing the 13s gear....
11-32: 11-12-14-16-18-20-22-25-28-32
this isn't entirely a serious suggestion
Posted : 06/09/2017 12:54 pm
