Road bike question ...
[Closed] Road bike question (sorry) - headsets
Sorry for the road bike question...!
I have a colnago arte (2008ish)- i need to replace the headset as it is dead. Any idea on what type of headset to replace it with? I think it is semi-integrated but dont fancy paying loads for a colnago one?
Cheers in advance
Posted : 26/03/2012 9:56 pm
There will be nothing special about the headset (as with any) - the trick is finding the bearings to suit.
If this sounds obvious, discard it, but check the type of bearing (angle and degree will be printed on the sides).
Start your search from there with the cheapest headset you can find (and keep your colnago branded top cap if it has one).
Let me know the bearing size as i have an FSA semi integrated in the box i'll never use if it helps you out.
Posted : 26/03/2012 11:40 pm
great, cheers, that was not obvious I will check!
Posted : 27/03/2012 9:35 pm
