Road Bike- bars kee...
[Closed] Road Bike- bars keep slipping.
[#4676614]
Whenever I hit a biggish bump on my road bike, the bars will rotate a wee bit downwards with my weight. Its a Ritchey stem, Cube Aero bars.
Tightened the **** out of the stem bolts already.
Any tips for keeping them locked?
Posted : 22/12/2012 10:10 pm
Less weight on the bars?
If you've already tightened up the stem bolts massively, I'd take it apart and check everything out. Is it new stuff? Maybe the bars are a bit thin, or the stem is a bit big?
Posted : 22/12/2012 10:13 pm
 gee
Sounds like you haven't done the bolts up evenly. Make sure the bars are centred in the clamp and that you have the same amount of thread visible on each bolt. Tighten them alternately.
Could be RM. I'd swapped the stem from my Cube to the Boardman, and its the Boardman thats demonstrating the issue. Might be one is 25.4, one is 26. Will check.
Posted : 22/12/2012 10:14 pm
Carbon assembly paste
It's like grease but with bits in it sort of like swarfega orange
Stops seat posts bars and the like moving with out crushing the hell of of them
If bars are alloy then I'd not recommend this fix as you prob have other issues
Gee- will check that out too.
Posted : 22/12/2012 10:15 pm
Check that there is not a high spot inside the stem. I once put a wee bit of wet n dry round the bars. It worked and I didn't die 🙂
Posted : 22/12/2012 10:19 pm
A bit of olde-worlde Roadie wisdom, although with the advent of modern technology and manufacturing processes this is, perhaps, a mite olde hatte by now:
Fit handlebars and stem made by the same manufacturer as small differences in tolerance and manufacturing techniques may present themselves in the form of creaks, or in extreme cases, movement.
But as has already been said...I would reckon bolts aren't evenly tensioned.
Don't over-tighten tho. Tight's tight, stripped's knackered.
Posted : 22/12/2012 10:20 pm
All good advice- cheers.
Posted : 22/12/2012 10:37 pm
Try some fiber grip
Posted : 23/12/2012 2:50 am
Take off, clean off any white residue with soapy water and dry. Tighten up evenly and slowly.
Make sure the bolts have their washers so they don't run out of thread.
Of course the 'old roadie in me' see's the word Cube and instantly blames that POS brand.
(POS IMO all rights reserved)
Edit. Ask for a mini torque wrench this Christmas.
Posted : 23/12/2012 8:43 am
what Vinnyc said, fiber grip will sort it, tried everything with a post and the=is stuff worked first time 😀
Posted : 23/12/2012 11:19 am
