Riding down steps a...
[Closed] Riding down steps and
36 Users
 wors
steep stuff, whats the best way to approach it? Tried ring down some steepish steps today but bottled it :twisted:.
Posted : 25/01/2009 8:02 pm
 jedi
dont even feather your front brake and roll all the way stay loose
Posted : 25/01/2009 8:03 pm
practice on less steep ones first
Posted : 25/01/2009 8:05 pm
 jonb
The best way to approach,
fast and straight, don't break on the way down unless there is no runout.
Posted : 25/01/2009 8:06 pm
saddle down and weight toward the rear.
the faster you roll the less 'thud thud thud thud thud' you get over the steps. a bit more speed and you float over.
start on small flights and work up. then start riding back up, again start small and build up.
yay. bikes
Posted : 25/01/2009 8:08 pm
Don't forget to shift your weight back
 jedi
if you gap stairs,use the second flight as a transition.
**** knows, steps terrify me, even the ones down from the top of Rivi Pike. I got down without dying though so must have done something right. I won't even attempt properly steep steps though.
Posted : 25/01/2009 8:11 pm
be aware that level landings on the way down can be tricky, you have to lean more forward as you cross them or you risk tipping off the back...
Ah, steps is something I'm good on, as I'm floaty light.
The faster you go, the less impact you will have on each step. You will 'skim' the edges, rather than bounce up and down each one.
There's quite a big flight coming down off the roundabout, at Canary Wharf, down to the riverside walkway. I just bomb down. The slower you go, the more bumpy it is.
Fast, weight back, DO NOT BRAKE. If you brake, you will go over the bars, and mash your face up.
Start small, with a low angle. The more of both the more the impact will be from angle-to-flat and the more you're likely to pick up speed
Use the rear brake as much as you like to start with.
Posted : 25/01/2009 8:37 pm
 ton
some bad bad bad steps round hebden.
give me the shivers thinking of em, they are that bad.
Posted : 25/01/2009 8:42 pm
 Sim
Move to Calderdale and you'll get good at riding them pretty quickly 🙂
Obviously that isn't entirely practical…
Posted : 25/01/2009 8:43 pm
Dollywagon Pike has some interesting steps. Would have been just about rideable for me except for the regular drainage ditches. Went over the bars a couple of times.
Posted : 25/01/2009 8:53 pm
Irregularly spaced stuff gets a bit harder:
[img] http://www.dur.ac.uk/cycling.club/photos/php/zenphoto/albums/mountain-biking/Durham/n61213742_39253205_37651.jp g" target="_blank">http://www.dur.ac.uk/cycling.club/photos/php/zenphoto/albums/mountain-biking/Durham/n61213742_39253205_37651.jp g"/> [/img]
And wooden board stuff harder again, especially if the backs aren't fully filled in
[img] http://www.dur.ac.uk/cycling.club/photos/php/zenphoto/albums/mountain-biking/Durham/n61213742_38962196_52402.jpg [/img][img] http://www.dur.ac.uk/cycling.club/photos/php/zenphoto/albums/mountain-biking/Durham/Mountjoy%20steps.jp g" target="_blank">http://www.dur.ac.uk/cycling.club/photos/php/zenphoto/albums/mountain-biking/Durham/n61213742_38962196_52402.jpg [/img][img] http://www.dur.ac.uk/cycling.club/photos/php/zenphoto/albums/mountain-biking/Durham/Mountjoy%20steps.jp g"/> [/img]
Posted : 25/01/2009 8:58 pm
Regular spaced and stable steps dont bother me, even steep ones, but wooden or irregular steps scare the bejesus out of me.
Posted : 25/01/2009 9:07 pm
I also dislike the bendy ones.
Posted : 25/01/2009 9:10 pm
Ooh, I'd love to do the ones in the Greenwich Foot Tunnel. Big spiral staircase. A full-susser might be preferable, to preserve the spine, and of course you'd have to ensure no-one was coming up the other way...
I'm going to try and do that, and film the bastard.
Posted : 25/01/2009 9:16 pm
$hit, link didn't work
Sorry
Posted : 25/01/2009 9:18 pm
Easy, if they aren't too steep...[img] http://picasaweb.google.com/VictorAnthonyPhotography/Steps#5277019401158746290 [/img]
Posted : 25/01/2009 9:21 pm
try again
Posted : 25/01/2009 9:22 pm
Calderdale does indeed have some great steps, the ones in Nutt Clough are my favorites.
Posted : 25/01/2009 9:25 pm
i thought he meant 'urban' steps at first.
here many steps in the wild are a small tree held back with spikes in the ground like those with boards shown above. when wet they are a ****ing nightmare if you don't hit the first one roughly square on. problem is they are often wet.
same applies when riding down tehm though. speed and skim over 'em...
Posted : 25/01/2009 9:38 pm
death grip on the front brake. If you're going to crash, then at least it's unlikely to be the fistful of brake endo(TM)
Posted : 25/01/2009 9:40 pm
You'll do well to beat Rivvi for steps, I was up there Sat morning.
Took a mate for a fast loop, thought it was great. You're Never too far from a nice climb (or a set of steps)
Posted : 25/01/2009 9:53 pm
when you ge good at steps you can progress to the endo...
[url= http://www.pinkbike.com/video/2594/ ]linky[/url]
Posted : 25/01/2009 10:16 pm
you were mentioned at the bottom of Nut Clough the other night 🙂
Posted : 25/01/2009 10:33 pm
Anyhow. Steps. Easy.
[url= http://uk.youtube.com/watch?v=_Ev1rb14JVk ]http://uk.youtube.com/watch?v=_Ev1rb14JVk[/url]
and
[url= http://uk.youtube.com/watch?v=we-9ebfqlcs ]http://uk.youtube.com/watch?v=we-9ebfqlcs[/url]
Posted : 25/01/2009 10:38 pm
"Don't use your front brake"??
You need to use a fair bit of front brake (and the rear) on steps around Hebden IME. You need to go down as slow as possible on some sets because of no run-out or sudden tight turn at the bottom etc.
Don't hang off the back of your saddle too much. Locked arms are of no use. Get low but more central on your bike. Elbows bent.
And yes, start easy/small/regular and go from there 🙂
Posted : 25/01/2009 10:52 pm
 jedi
yeah dont.
until you're comfortable doing simple stairs
Posted : 25/01/2009 11:02 pm
 devs
Nobody has done these
DSC00454
But these are great fun
I find weight back works and you DO have to brake and almost trackstand to get round some of the bends on some of the steps I've done.
Posted : 25/01/2009 11:29 pm
 jedi
yes you do use your brakes(both) but not your front if you have never ridden down steps before and are learning
Posted : 25/01/2009 11:34 pm
Fair point 🙂
Posted : 25/01/2009 11:35 pm
Devs - whereabouts are they? 🙂
 devs
The nice ones are between Cullen and Portknockie on the Moray Coast. The unridable ones are called the Giant's Steps and are east of Cullen on the coastal path. It's a great ride but that bit is quite intimidating even on foot. We rode the grass to the right after carrying down the first half. The "steps" at the top are 3ft drops with little ledges to stand on. I'm sure Hans Rey or Danny Macaskill could do it but no one has as far as I am aware.
Posted : 25/01/2009 11:45 pm
Those looks fiendish....but possibly do-able on a dh bike. Not sure I'd want to guinea pig them though.
Posted : 26/01/2009 1:01 am
what i find is, on regularly spaced steps it all seems a bit too easy until you start going too fast and thats when you lose control- it all gets a bit too bouncy! so you need to keep it smooth and controlled so as not to HAVE to use your brakes too much.
If youre going too fast and need to slow it down remember that too much of either brake will cause you to A) go into a back wheel skid or B) go over the bars. I'd rather over-brake using the rear than go over the bars any day but a bit of front brake applied at the right time is often a lot more effective in slowing you down. The more you get a feel for these things the more you learn how much of each brake you can get away with.
i'm a bit of a wuss on irregular steps. especially if they're wet/muddy. If i can see a good place to bail (like on devs pic there's a grass banking on the right. still look bloody steep though!) but if they're steep and trecherous i tend to walk and be really pi**ed off with myself afterwards for not giving them a try.
Posted : 26/01/2009 9:02 am
 wors
Im usually okay on most things but these were urban steps, and pretty steep with it. I'm gonna give it another go tonight!
Posted : 26/01/2009 9:36 am
Ooo I love steps riding 🙂
Would love to have had a go down these beauties but had the road tyres on 🙁
And significant kudos if you know where they are...
TM
Posted : 26/01/2009 10:26 am
These in Nottingham are good fun; they start off steep and scary but the spacing of the lower sets exactly matches your wheelbase and are a right giggle.
[url] http://flickr.com/photos/49369724@N00/2695921577/ [/url]
As they say, "Practice makes Perfect", just keep building up until you're confident on higher sets.
For what it's worth, I always find that I've got much more control on a rigid bike - for example, on the packhorse trail down Stanage... Maybe not as fast as with a bouncy fork, but the bike is much more controllable.
Posted : 26/01/2009 3:23 pm
Twiglet - are they in Odessa...
Posted : 26/01/2009 3:33 pm
Posted : 26/01/2009 3:36 pm
Oops. Pic above at Cwm Carn. Bit tricky as irregular as **** and pic doesn't really show how steep they really are.
Posted : 26/01/2009 3:37 pm
St Ives in Cornwall has some good steppage.
I wont mention Parkin Clough.
Posted : 26/01/2009 3:38 pm
Fun local set at top of [url= http://uk.youtube.com/watch?v=-ffCIYfoOEc ]mmmbop[/url].
Posted : 26/01/2009 3:39 pm
http://www.unicyclist.com/index.php?page=gallery&g2_itemId=125951
They are a bit slippy slidy though and steep and tight, and yes, like you say, have someone at the bottom to check no-one is coming, you can see bugger all from the top.
I think we may have waited till the lift was going up from the bottom to run it*, cos then you don't get noticed. We didn't get any hassle for doing it anyway.
Joe
*When I say 'we' I took the sensible option of taking photos for this one. I'm a big fan of not being dead.
Posted : 26/01/2009 4:13 pm
Devs, I reckon the giant's steps will 'go' one day. They're an ambition of mine.
Posted : 26/01/2009 4:43 pm
brant - Member
Ooooh the fame! 😉
Posted : 26/01/2009 4:55 pm
 devs
Can I watch Jo? I'll get the air ambulance on standby. I'd do them on skis but I think I can safely say they will always be beyond me on a bike.
Posted : 26/01/2009 5:08 pm
where exactly is mmmbop? i saw it in the singletrack calendar but can't figure out where it is. can't be far from me...
Posted : 26/01/2009 8:43 pm
will you lot leave my Clough out of this please?
is nothing sacred?!?
Posted : 26/01/2009 8:48 pm
I'm not having that. Doing it on a unicycle. I reckon he's holding on to the rail. You'd have to grab it, to slow down, anyway. No way could you clear that without slowing, you'd kill yourself.
No, not having that.
Posted : 26/01/2009 9:19 pm
Looking at the angle I think he's hopping down step by step rather than rolling down them.
That said, I've seen people do rolling hops at speed onto similar staircases so I wouldn't be in the least surprised if someone could ride it. Like Joe, I prefer my limbs intact, but there are loads of 16 year olds throwing themselves off stupid things on unicycles; a mere set of stairs would be nothing.
Posted : 26/01/2009 9:44 pm
[url= http://i419.photobucket.com/albums/pp271/repackrider/avatar235.jp g" target="_blank">http://i419.photobucket.com/albums/pp271/repackrider/avatar235.jp g"/> [/IMG][/url]
[url= http://sonic.net/~ckelly/Seekay/mtbwelcome.htm ][b]2retro4u[/b][/url]
Marin County, Cali
Me in 1977
______________________________________________________
[b][i]Orwell was a f#$king optimist.[/i][/
Posted : 27/01/2009 5:58 am
Near t'top of Jack Bridge climb, dropping off right to the packhorse bridge.
Posted : 27/01/2009 7:40 am
In an mmm bop they’re gone. In an mmm bop
they’re not there.
In an mmm bop they’re gone. in an mmm bop
they’re not there.
Until you lose your hair. But you don’t care....
Posted : 27/01/2009 8:09 am
 wors
[url= http://uk.youtube.com/watch?v=sCvlshB-TjA ]Think i've cracked it.[/url]
Posted : 31/01/2009 7:06 pm
