My revs are leaking a small amount of oil from under the compression/ lock out knob nothing major but I was wanting to know really if this is common, what will eventually happen and should I get them serviced. Money is a bit tight at the min so I am hoping they will just be ok I guess. I have some other forks with dodgy bushing so might ask for a bulk discount at the fork fettlers if the service is really needed! cheers.
Posted : 12/08/2009 5:30 pm
Sadly perfectly normal. You'll know if you lose to much oil as the lockout won't work if the oil level drops below the MC circuit.
Posted : 12/08/2009 5:36 pm
cheers nuke, i will start saving for the service I think, on the tf tuned site it says they replace the seals with better ones to solve the problem!
Posted : 13/08/2009 6:39 am
