reverb vs GD vs com...
[Closed] reverb vs GD vs command post
for those that have them could they list the pro's and cons of each, and then I can have an idea about which is besterest and most reliable..
Posted : 09/10/2011 6:17 pm
Reverb - faultless for six months. None of the hassle of cable operation.
Posted : 09/10/2011 6:33 pm
+1 for what nonsense said also looks the best.
Posted : 09/10/2011 6:36 pm
was pretty much thinking along the same lines, just need to save the funds now!!
Posted : 09/10/2011 6:45 pm
Hi Carl. 12 months on a command post, serviced once by Certini. Faultless. Only change I've made was to swap the original lever for the newer design. When doing that I removed the noodle and put a couple of middleburn in liners in place.
Posted : 09/10/2011 6:50 pm
Command post here. Had it a year. No problems, easy to service. Would probably get a reverb if I was buying a new one though.
Wondering what hassle people have had with cable operation?
Posted : 09/10/2011 6:54 pm
 bol
Gravity dropper here. No slop, 27.2 diameter so fits anything. Reliable and easily serviced. Not pretty.
Posted : 09/10/2011 6:57 pm
my riding pal has the command post...also faultless over a year or so....if I went for one of them, having Certini nearby would help if things go wrong, but, I like the look of the Reverb and the switcharoo thingy on the bars....ummmm decisions decisions...
Posted : 09/10/2011 7:00 pm
The new one from Giant looks the biz and a bit cheaper than the Reverb
http://bikemagic.com/gear/giant-switch-seatpost-released.html
Posted : 09/10/2011 7:04 pm
Gravity dropper here. Not touched it in the five years I've had it and it still works perfectly.
Apparently not pretty, but I can't see it when I sit on it!
Posted : 09/10/2011 7:09 pm
around £160 which is more palatable for my wallet..will do some research.
with the GD's does the 1" drop setting actually get much use or is it normally fully up or down all the time? 1" doesn't seem worth bothering about?
I like the GD's because of the mechanical nature and ease of replacing parts as they wear out, but man alive they are fugly!!!
Posted : 09/10/2011 7:11 pm
Gravity Dropper Classic - faultless for five & a half years. None of the hassle of leaky hydraulics.
 juan
GD, very little parts inside, hence very little to go wrong.
Posted : 09/10/2011 7:28 pm
Nonsense - Member
People keep saying that, but what hassle is this that you speak of? Both of mine are cable operation- as are all my gears and some of my brakes 😉 And all work fine.
OTOH lots of people seem to have trouble bleeding Reverbs.
Posted : 09/10/2011 7:29 pm
Reverb post can be had for £190 from Hibike delivered and in under a week, all me and my mates have got ours from their.
Bleeding the reverb post is a sinch and only needed as you get a long hose length so need to shorten to required length, no different than any disc brake.
Posted : 09/10/2011 7:54 pm
1" drop used all the time. Fully up for fire road and climb, 1" for techy rolling singletrack, fully down just for proper steep stuff. Pretty sure if you got an infinite adjustment like a reverb, command post, joplin etc it would spend most of its life at low levels of drop.
Posted : 09/10/2011 8:17 pm
My reverb broke after 10 rides, stopped holding air. Fixed now. Hose coming out of the upper moving part is a PITA.
Posted : 09/10/2011 8:22 pm
+1 for the 1" drop. 80-90% of riding. Fully up for big climbs, fully down for gnarly, 1" down for general riding. With the Command Post it indexes to these positions really easily.
Posted : 09/10/2011 8:23 pm
@ nickjb so if i went for the 5" multi drop post with the 1st drop being 2" instead of 1", do you reckon it'd be too much for general razzing around...
Posted : 09/10/2011 8:40 pm
Reverb is awesome when it works, mine has blown twice already, it just stopped holding air whilst riding and if you tried to pump it back up it would leak straight out again. Fishers have been good at sorting it out though to their credit.
Posted : 09/10/2011 8:42 pm
ive had a gd for a few months and been faultless so far
pros
not very heavy
i beam compatible
survived a week in the alps
dead easy to take apart
no sign of slop yet
27.2 so fits my frame!
cons,
in use its a bit clunky
i too use the 1" drop quite a lot for razzing about
Posted : 09/10/2011 8:47 pm
I was very sceptical that about the usefulness of the drop options as it didn't sound like enough but the 1" is perfect for me. Its high enough to still pedal but it feels out the way enough for XC riding. When its gets very techy I just drop it all the way. Maybe try riding your current post at 1" or 2" below a good climbing height to see how it feels
Posted : 09/10/2011 8:49 pm
GD do a 30.9 without a shim now so would be looking at that i reckon.
I like the idea that if (when) something does go wrong I can sort it out myself in the garage and not have to post back etc etc
The GD is looking favourite so far just need to sort out which one i need, turbo multi I think but will have to measure up my existing post to see what length to get.
cheers nick, i drop raise my saddle constantly but never by just a tad so may try it tomorrow at some point see how it goes..
Posted : 09/10/2011 8:51 pm
I might be talking out of my backside here, but wasn't there some issue with the GD'd that meant you weren't supposed to use the 1" drop position?
Posted : 09/10/2011 10:50 pm
