As above, LBS fitted new lever on my wifes reverb and now after two rides it has stuck at the bottom and "sucks" back down if you press lever and gently pull on it.
Will a bleed cure this or are there more difficult things afoot?
Thanks in advance.
Posted : 23/03/2020 5:30 pm
I'd start by bleeding it and seeing what happens. Any leaks?
Posted : 23/03/2020 6:19 pm
nope, all good on that front. ...
Posted : 23/03/2020 9:17 pm
Do you want the obvious answer??????????
Posted : 23/03/2020 9:21 pm
best tell the wife, Brand X im assuming;)
Posted : 23/03/2020 9:35 pm
Did you have the new 1X remote fitted?
Posted : 23/03/2020 10:20 pm
I'd give it a bleed before you do anything else. Mine was the same over chrimbo. Reinflated and bled and it's perfect
Posted : 23/03/2020 10:39 pm
When mine did this after a rebuild, (snapped at lever during crash) the hose wasn’t cut straight and caused a leak. Recut and rebled all fine
Posted : 24/03/2020 9:03 am
