Looks like the hose bend may just be *JUST* too tight without putting a bend in the hose. Local shop are having a look, but thought I'd ask the question. Is it possible to run a reverb stealth without the connectormajig meaning if I ever want to remove the post, I'll just have to bleed the post after.
Any experience anyone?
You can use the old style hose which has no connectormajig
Spot on thank you!
Uberbike do a version without the connector
Do your future disconnections at the lever, and screw the red barb that should have come with the post, into the hose, and you probably won't need a bleed, and if you do then it'll just be needed at the lever end.
[url= https://www.uberbikecomponents.com/view-product/Uberbike-Rockshox-Reverb-Stealth-Replacement-Hose-Kit-Colour-Options ]UberBikes [/url]
fit a DeHy
