Removing SRAM conne...
[Closed] Removing SRAM connectamajig from Reverb Stealth
[#7601772]
Hi,
just want to see if anyone else has done what i am planning on doing really...
My reverb stealth won't fit on my new bike as the connectamajig is too long and it hits onto other frame parts before i can get teh saddle low enough on the max extension.
its only about an inch too high so i reckon i can remove the 2.5" long connectamajig and replace it with the old style strain relief dodad and it should drop in nicely with no contact.
Has anyone else done this to their reverb at all? any issues? is the connectamajig actually removable?
Thanks all
Posted : 25/01/2016 12:53 pm
Hard to tell if you will be able to save one inch:
On the other hand, it should be a fairly cheap experiment - part no. 11.6815.022.010 is about £8 on ebay.
Posted : 25/01/2016 1:12 pm
it is definitely over an inch and for once, that inch will make all the difference...
Posted : 25/01/2016 1:17 pm
yup removed it here
screwed a barb in re bled..
Posted : 25/01/2016 1:24 pm
Although, now that I really think about it, the connectamajig male part is crimped on, so you will end up cutting it and shortening the hose.
If the hose ends up too short you will need the full hose + barb kit, which is about £24 ( 11.6815.025.010 )
Posted : 25/01/2016 1:25 pm
i've got tonnes of length left as it came off a Large mondraker, could probably plumb two bikes up with it!
Posted : 25/01/2016 1:38 pm
I had same issue. Removed the connectamajig and added the £8 part. Took a couple goes to get the hose perfectly sealed on the £8 part, but now its fine.
Posted : 25/01/2016 1:42 pm
just a quick update to let anyone who's thinking of doing this that it works fine and chops almost 2" out of the overall rigid height of the post.
Posted : 08/02/2016 12:33 pm
Yeah, did it here too, connectamajig just seems like a pointless complication for most folks.
Posted : 08/02/2016 12:36 pm
