Reverb set up quest...
[Closed] Reverb set up question...
just installing my reverb and seems to be that in order to get the saddle to sit straight, the back screw is much more through the locking nut than the front screw is over the saddle rail- is this normal?
Also, don't get the angles printed on the side of the post - 0 degrees certainly isn't a flat saddle!
If this is all normal, then thats great
Posted : 03/05/2014 3:53 pm
0 degrees can only be a flat saddle depending on the angle of your seatpost. If your seattube is a funny angle then it can't be right
Posted : 03/05/2014 4:16 pm
My rear screw is about 3-5 mm more proud than the front, as above will depend on your seat tube angle.
Posted : 03/05/2014 4:29 pm
thanks for the answers
Posted : 03/05/2014 6:23 pm
