Reverb returning ve...
[Closed] Reverb returning very slowly what to do?
Reverb is returning very slowly not touched it for around 6 months does it just need a bleed (got the kit).It is @ the + max on the lever.
Not sure about air pressure instruction says do not tamper with the air presures or it will need to come in for a service!
Posted : 15/10/2012 5:44 pm
Take it out have a look at the bottom, you will see the shrader cap remove, fit pump and put 250 psi in it.
Posted : 15/10/2012 5:46 pm
Probably just needs bleeding, mine was doing same until it was bled.
or you've lifted your bike up by the saddle ( a BIG no-no) and bust the seal.....
Posted : 15/10/2012 5:52 pm
Mine did the same til it was bled.
Posted : 15/10/2012 5:53 pm
Another vote for bleeding it.
Posted : 15/10/2012 5:55 pm
Thanks sorted out my evenings entertainment! just need to coax the other half into the garage!
Posted : 15/10/2012 6:00 pm
It's dead easy - should only take 10 minutes if there's two of you - let us know how you get on ๐Ÿ˜†
Posted : 15/10/2012 6:02 pm
Well working together was not that successfull so I sacked her! Reverb has never worked so well even since new, what a differance its like a bloody ejector seat.
Just one question on the bleed screw on the seatpost I take it it has a black o ring on it? as when I took it out it did not! it was not untill i tried screwing the syringe on it was not going on very well.I took in off and a little mangled o ring appeared so i have presumed it fits on top of the bleed screw!!!!
Rich
Posted : 15/10/2012 8:10 pm
