Hi all I've been doing a reverb stealth B1 50ht service. The retaining ring at bottom of post is pretty hard up. Does anyone know either the SRAM part number or the retaining ring dimensions sonic can order a new one without shelling out £60 on a full 400 HR kit
Thanks
Good luck with that, I had exactly the same problem, the traditional circlip is too thick and you can't buy the retaining ring they now use from anywhere and I looked very hard!
LBS tried without luck as Rockshox wouldn't supply other than buying the full service kit.
The solution we came up with was to make a fixture to hold the normal circlip and using a surface grinder reducing the thickness. There is another way but that will invalidate any warranty.....
If you do manage to find a supplier can you post back where from please..
Sorry to bump up an old thread, but I've got a sample of these clips coming this week, if they are ok i'll have a few available, they're stainless as well, so won't rot away like the original.
