Reverb help
[Closed] Reverb help
Hi guys. I needed to bleed my reverb as it stopped returning and after 2 hours of fruitless effort I realised I had a leak on the post connection end. I fixed it and rebled which worked much better but I now have a slight, maybe 15mm sink on the saddle when I put weight on it. It returns and does what it should but I'm sure it shouldn't go down a little when weight is applied. The air pressure is around 250 psi so I'm now stumped. Any advice appreciated Thanks.
Posted : 14/02/2013 6:48 pm
Stubborn air bubbles. Keep bleeding mon ami.
Posted : 14/02/2013 6:59 pm
Really? Thanks mate I better leave it for tonight with all the valentines stuff going on but I will rebleed tomorrow. Cheers.
Posted : 14/02/2013 7:01 pm
 fbk
Sinking when you sit on it doesn't sound like a bleed issue tbh. The manual does say if the post still drops a bit when you sit in it, it needs to go back to the manufacturer. Is it still under warranty?
Posted : 14/02/2013 7:35 pm
No mate its not, it never did it before the leak and now does after my repair.
Posted : 14/02/2013 7:46 pm
I've just found out if you pump the remote the post goes solid. So maybe it is the bleed after all.
Posted : 14/02/2013 7:50 pm
