Revelations/sektors...
[Closed] Revelations/sektors - tyre clearance?
What is the widest tyre you can fit to these forks?
I have 2.4 Advantages on 47mm rims, need around 65-70mm at the widest point on the forks. Will any of these work?
Posted : 07/11/2011 12:44 pm
 loum
I don't know for certain, but can confirm that a 2.4 Advantage tyre on flow rim fits nicely in my lyriks fork
Posted : 07/11/2011 12:50 pm
2.4 Advantage no bother- it won't be generous but it'll be more than big enough. Older Revelations had smaller crowns though.
Posted : 07/11/2011 1:22 pm
I've got a 2011 Rev WC XX's with an ADvantage 2.4 on at the minute, no problem with fitting. It's on an 819 if that helps.
Posted : 07/11/2011 2:23 pm
2.3 eskars in mine, on EN521 rims. Still got masses of room.
Posted : 07/11/2011 2:27 pm
 wors
I have a 2.5 minion in mine which fits fine.
Posted : 07/11/2011 2:28 pm
Thanks everyone,I think I will go for a set of rev's 8)
Posted : 07/11/2011 2:40 pm
