Revelations leaking...
[Closed] Revelations leaking oil - seal kit advice
My revs are leaking oil, I can't ignore it anymore.
It is the usual U turn problem so nothing too serious but it is now time to fix them.
There are loads of seal kits available. I could buy the genuine full service kit from Rockshox but I've also seen the ones for sail by "evilhomersimpson" on ebay. Dose anyone know if these will contain the bits I need? I'm no too bothered about doing all the internals as the forks are otherwise running pretty smoothly. I think all I need is a couple of small o rings and the crush washers but it isn't that clear even after looking through the service instructions.
Anyone done this? They are 2009 forks.
Posted : 22/08/2012 10:24 am
I did my coil u-turn revs using the non-u-turn evilhomersimpson o-rings (and pukka rockshox foam rings/seals). They had everything I needed to fully service the moco + the couple of rings in the coil side.
If you have an air u-turn I think he now does one for that too with the extra bits. Since you have them apart and you get the full kit I'd just change the whole lot. His supplied instructions are pretty clear.
Posted : 22/08/2012 11:00 am
