Does anyone know if it is possible to space a 29er revelation down to 110 or 100mm travel? I know technically they only go down to 120mm, but you never know!
Cheers,
Ian
Posted : 11/04/2013 3:11 pm
110 should be fine, not 100% as to 100mm though. (my 150 dual air 26" revs are spaced to 120mm)
Posted : 11/04/2013 3:13 pm
hmmm tempting then... thanks!
Posted : 11/04/2013 3:23 pm
That the dual airs 2012, the 2013 solo airs you need to replace the air spring assms. ๐
Posted : 11/04/2013 3:26 pm
Yep, the ones on chainreaction for (sort of) cheap... they're 2012 dual air RL revs, so I should be able to get them down to 110mm, then just run a bit of extra sag or neg air...
Posted : 11/04/2013 4:18 pm
