Resistance threadin...
[Closed] Resistance threading BB shell - things to try before chasing?
Got delivery of my new Ti frame yesterday. Drive side cup threads in nicely, but the NDS is pretty resistant. I've given it a bit of a brush and spray with IPA but that hasn't done much.
Anything else I should try before bothering the LBS (who have a huge waiting list at the mo)?
Posted : 19/06/2020 9:25 am
Pics?
Posted : 19/06/2020 9:35 am
Ask Renton to do it for you?
I'd use grease instead of IPA though, if it still catches then stop and get the threads cleaned up properly.
Posted : 19/06/2020 9:41 am
Is it a new BB?
Does it have threadlock pre-applied?
Do you have another frame you can fit the BB to?
Posted : 19/06/2020 9:45 am
I have a toothbrush sized wire brush that I always use before BB installation, BB threads are pretty fine and a tight fit, it doesn't take much debris in there to cause thread pick up. You could also take the threadlock off, and apply a light grease or even oil (like a cutting fluid grade) to get you home.
Posted : 19/06/2020 9:50 am
Thanks all. No pics as I'm posting this while toddler-wrangling.
I guess I'd just expected that the BB would screw in loose by hand - I was just popping it in to see what it looks like.
I'll give a wee dab of grease to see how that goes.
There's a wee bit of swarf in the headtube and seat tube as well so I suspect that the frame needs a decent clean before starting to build.
Posted : 19/06/2020 10:07 am
