Replacing WTB Riddl...
[Closed] Replacing WTB Riddler 37s ???
I've got a Sonder Camino AL and at first I loved the Riddler 37mm tyres that came with it as they were great on mixed terrain. Annoyingly in the last 6 months I've had a stupid amount of punctures ...mostly thorns.
So what Riddler like pattern tyre can I replace them with? Max width 38mm but with puncture protection. Before you say it, I'm not going tubeless as I'm too stupid to set them up.
Any ideas?
Posted : 26/07/2019 9:41 am
Tubeless. Sorry had to be said. If you cant do it, your LBS will do it for you.
Anyway tyre wise, Gravelking SK is the stock answer. or I like Kenda Flintridge for a tough tyre that grips really well.
Posted : 26/07/2019 9:52 am
WTB Nanos, 40mm but according to the Alpkit website the Camino AL has clearance for them.
As above, go tubeless - not had a single puncture on my Riddlers
Posted : 26/07/2019 9:58 am
It's a v1 Camino and Alpkit reckon the Nanos are too wide for it, hence max 38mm
The wheelset is the standard LoveMud Orbit so tubeless ready, so going tubeless is tempting but a little scary. What happens if I'm 20km from the road in France or somewhere and I have a problem?
Posted : 26/07/2019 10:24 am
. What happens if I’m 20km from the road in France or somewhere and I have a problem?
Stick in the spare tube you'll be carrying.
Posted : 26/07/2019 10:27 am
Anyone got a link to an idiot's guide to tubeless?
yes I know, I'm 10 years late but not all of us are cycling Gods
Posted : 26/07/2019 10:31 am
Plenty online and I think STW did one but here's a page https://thecycleclinic.co.uk/blogs/news/living-with-tubeless-tyres that's more road oriented about dealing with things out on the trail/road.
The only time I've had a problem out on the trails is when I've dinged the rim and the tyre wouldn't seal - the ding was bad enough that I trashed the rim. Apart from that, tubeless is virtually fit and forget, you just need to top up the sealant now and again.
Posted : 26/07/2019 10:44 am
Gravelking SK or G-ones are small knobble tyres like the riddler, Nanos are more tready and slower on the road IME
Posted : 26/07/2019 11:46 am
Hello ElShamino
I posted a very similar thread a few months ago: loved the Riddlers, but I was averaging more than a puncture per week.
I replaced them with Vittoria Revolutions. These may well not fit your use case, as they have much less tread. However:
- they are great on the road. Loads faster and no problems with grip
- they are good for light-to-medium off road when it's dry
- they are ok in the wet
- I have not had a single puncture since I got them
- they are useless on wet grass
Take a look, I could not be more pleased with mine.
Posted : 26/07/2019 12:44 pm
@easily - thanks
Posted : 26/07/2019 1:09 pm
I had the same problem with Riddlers and switched to Gravel King SK. Much better puncture protection, good enough grip, ok on the road.
Posted : 26/07/2019 1:43 pm
I've recently bought 3 tubes so I'll stick with normal tyres for now.
Also, I emailed AlpKit and they said I could go up to 40mm max on the v1 Camino.  So the WTB Nanos may well fit.
@scotroutes - silly Q, why would you carry a spare tube?
Posted : 30/07/2019 2:46 pm
If you get a problem big enough that tubeless doesn't work you'll then need a tube. most folks running tubeless on a biggish ride (where you can't or don't want to walk home) will carry a tube
Posted : 30/07/2019 2:55 pm
thanks
Posted : 30/07/2019 2:57 pm
I have riddler 45c on mine set up as tubeless. Many miles completed inc. week cycling on/off road in france and still not had a puncture.
Posted : 30/07/2019 7:22 pm
Thumbs up for 40c Nanos. First ride I still had tubes in = a double puncture. However after setting up tubeless they have been flawless over hundreds of miles and also racing at Grinduro recently.
Tempted to put a 45c Riddler up front for extra bite though 🤔
Posted : 30/07/2019 7:50 pm
