Yes, those are bushes. Buy a cheap tool and poly bushes off ebay, job done in 10 minutes.
You also need to replace the 2 alloy bushes that fit into each of those inserts , they will be where the play is coming from . There are various sizes used so make sure you get the right one for your bike .
This is why I'm confused! 🙂
TF tuned website has a good guide for what size bushing for what shock, covers most common shocks. As above, recommend the poly bushes rather than alu.
not always. depends how long you leave them to knock for.
havent had to replace any since I started using the plastic bushes.
Kaesae off here is helpful with this stuff. He has an ebay shop (Kaltech?)
Gives advice, sells the bushing and a cheap tool to make the job really simple.
Hmm, has been knocking for a bit and I do ride with not much in the way of mechanical sympathy. Is it easy to tell if the reducers are worn too?
Yeah. Replace the bushings, if the problem persists you need to look at the reducers as well. The bushings are designed to go first.
Make sure you buy a tool as I extracted a bush with a socket to drift it out an by mistake oversized the hole. So I now have a small amount of play even after I had them serviced by TFTuned with the new polly bushes.
reducers can wear out too and need replacing, if that happens I'd replace the entire bike with a fatbike
I bought a strong bushing and tool from BETD way back (fits Stratos and Fox shocks) and it's dead easy to replace the bushing itself. If you find yourself over York way I'll lend you the tool.
Standard bushings are designed to wear first, to avoid issues with the rest of the bike. Treat them as consumables like bearings.
Jase - in the same situation. Just bought a tool and a pair of bushings for £12 posted on ebay. See how that goes...
