Replacing car fuse ...
[Closed] Replacing car fuse must understand common sense
There are many car circuit electrical equipment to be connected wires of different colors, which most can not be ignored should be fuse. Fuse is a habit called, said the national standard fuses. The role of the fuse is to protect the circuit (wiring) and electrical equipment, not because of a short circuit, overload and overheating fault damage, and even fire. So in a sense, the fuse wire is life insurance, do not underestimate it, use it as an afterthought.
We often find that occasionally when using the vehicle headlight wipers does not shine or no fault, encountered such a situation we should first suspect there may be damage to the fuse, fuse box located in a different position of the vehicle, look for a black small plastic box, open the plastic cover on the back marked with the location of each fuse, function and amperage. Fuses can also differentiate to distinguish from the color, such as: yellow is 20 amps, 15 amps for blue, red for 10 amps. We can make use of a special tool to remove the insurance fuse box to be checked (Remember: Be sure to turn off the [url= http://www.maxspeedingrods.co.uk/ignition-coils.html ]ignition coils[/url] switch). When replacing the fuse must be consistent with the wife fuse specifications, can not arbitrarily increase the fuse current rating, but can not use other conductive material instead.
If put to the fuse blows immediately, indicating that the circuit has a short circuit fault, to ask professional troubleshooting and then install the fuse, do not use to increase the fuse size to deal with, or is likely to cause a fire.
Also like to remind everyone that, many [url= http://www.maxspeedingrods.co.uk/ ]engine parts[/url] stores sell shoddy fuse, no insurance. So be sure to use when buying genuine parts.
Recommend blog [url= http://enginerods.weezblog.com ]http://enginerods.weezblog.com[/url]
Posted : 05/12/2014 9:15 am
Thanks
But reported
Posted : 05/12/2014 9:20 am
Thanks
But reported
Twice. ...
