replacing bottle ca...
[Closed] replacing bottle cage boss in alu Allez frame North West
Does any of you good folk know a place in South Manchester/Cheshire that can replace a bottle cage boss in my frame, the whole carcass of the rivet is turning in the frame and would like it replacing/fixing so that I can accommodate two water bottles
Posted : 30/06/2014 10:54 am
You can do it with a rivnut.
you'll need a pop riveter, drill the old one out, insert the rivnut and squeeze.
Posted : 30/06/2014 11:05 am
You don't, you can do it without one. It's easier ith one, but there are plenty of online guides to show you how to do it with basic tools and a few nuts and bolts.
The difficult bt is removing the end that falls into the frame tube once you've drilled off the head.
Posted : 30/06/2014 11:08 am
http://singletrackworld.com/forum/topic/rivnut
Posted : 30/06/2014 11:12 am
I did see the rivnut method, ill have a look on the line, would feel better if someone could do it though locally.
dont suppose i will need the tool very often if I bought one
Thanks guys
Posted : 30/06/2014 12:04 pm
Probably no need to remove the old one. It's not hard to tighten them up in many cases.
Posted : 30/06/2014 12:21 pm
I used this method - http://www.parktool.com/blog/repair-help/water-bottle-fittings
Worked a treat!!
Posted : 30/06/2014 12:24 pm
ill try a method of tightening but I suspect its threaded and the guy who had the frame before messed it up (2006) its taken me a long time to look into getting it sorted I know!
what size is the bottle cage thread if I was to replace?
Posted : 30/06/2014 12:30 pm
This is true, alhough it's wearth bearing in mind that the rivnut is usually a soft allow, and if it's been damaged, it's probably better to simply replace. it. If a bolt is stuck in, it can be a right bugger to remove, especialy if the cage is still attached. Bolt is m5 size. Rivnut is probably 8mm diameter with m5 thread.
Posted : 30/06/2014 12:35 pm
there is no bolt stuck in fortunately, I bought the frame knowing it was bagel so I never bothered until recently its niggling me to get it fixed now, saying that I am not even sure if the thread is damaged, I will try a quick tighten and if that fails I will replace the rivet for a new one
Posted : 30/06/2014 12:48 pm
