I have a set of Mavic CrossRides that have developed a bit of play in the bearings. Are the bearings readily available from most places? have found [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=29467 ]THESE[/url] on CRC but they dont mention which wheels they are for, can anyone advise?
Also, is it an easy-ish job to do? (i've never done something like this before but want to give it a go)
Think i'll replace both front and back whilst i'm at it.
no idea about bearing replacements, but you can adjust the play/tightness on crossrides: they have spanner flats on them similar in appearance to shimano ones, and some blurb in the instructions about it. I never needed to on mine (since sold on classifieds here) but I think the process was just like shimano ones ie loosen outer one, nip up inner one and tighten outer one again to lock together.
interesting Julian, will check that out later. might save me replacing the bearings if its just those nuts.
