Replacing bearings ...
[Closed] Replacing bearings on HTII BB - easy?
 Jase
Is replacing the bearings on a HTII BB easy?
I'm guessing it would be a lot cheaper than replacing the whole unit.
Posted : 31/07/2011 6:04 pm
dead easy with the right tools, if you want to borrow said tools and are in derbyshire then you are more than welcome
Posted : 31/07/2011 6:06 pm
I didn't think the bearings were replaceable? interested if anyone knows otherwise too!
Posted : 31/07/2011 6:07 pm
Easy to do. YOu have to find the right size bearings tho - they actually vary slightly between different manufacturers
Posted : 31/07/2011 6:08 pm
 Jase
cruzheckler - cheers but in Bucks.
They are Shimano.
Any ideas if any instructions exist which will also include details of required tools?
Posted : 31/07/2011 6:10 pm
 Jase
Looks good, I may even have the bearings too ๐Ÿ™‚
Posted : 31/07/2011 6:19 pm
As TJ said, the bearings Shimano use are narrower than std ones. Even so I stuck them in & just did away with one of the spacers either side. Has been working fine for few months. Be gentle with the "top-hats" as they split easily.
Posted : 31/07/2011 6:21 pm
sweet, looks quite easy!
Posted : 31/07/2011 6:22 pm
Not [url= http://www.singletrackworld.com/forum/topic/confused-ht2-bearings ]quite that simple.[/url]
Posted : 31/07/2011 7:41 pm
