Replacing a Shiman...
[Closed] Replacing a Shimano brake lever
Ello, a prang a while back resulted in my brake lever being bent 90 degrees. How do I go about changing it as it isnt immediatly obvious how to ge tthe lever off?
Cheers,
Posted : 30/10/2009 2:47 pm
Which Shimano lever is it? There will be a model number stamped on the underside of the clamp.
Posted : 30/10/2009 2:53 pm
Its an LX lever, in work at the mo so will check when I get home. ๐Ÿ™‚
Posted : 30/10/2009 3:00 pm
Just checking it wasn't a 485 or 486 as those blades can't be removed.
Posted : 30/10/2009 3:04 pm
I just bent my XT one straight again. Jobsagoodun ๐Ÿ™‚
Posted : 30/10/2009 3:50 pm
How did you do that Dezb? I couldn't get mine to give even slightly, the impact that caused it was enough to break my wrist though.
I think I would worry about it snapping when in use if I bent it back.
Posted : 30/10/2009 4:00 pm
Oh, I was worried, but I was halfway down an Alpine pass at the time. It was either bend it straight or walk the rest of the way down! Xt levers are probably softer ๐Ÿ™‚
Posted : 30/10/2009 4:52 pm
