replacement seatpos...
[Closed] replacement seatpost/saddle bolt - what size?
Probably varies between posts, but is there any kind of standard size for the bolt that holds the saddle rails, clamp and post together? Snapped one yesterday and now on the lookout for a likely replacement, but left the original at home. Its an M7, but not sure about length, any ideas?
I will not be shocked if its a weird non-standard size to force you to replace the whole post, but going to try the hardware shops shortly.
Posted : 30/06/2009 12:01 pm
They're not a common size between posts, but if you get one too long you can always cut it down (with a nut on it so you can sort out the threads aftewards of course.
With how much bolts cost, why not just but a couple?
Posted : 30/06/2009 12:06 pm
