Replacement PF92 BB...
[Closed] Replacement PF92 BB Options
Morning all
Need to replace the PF92 BB on my Trek Fuel Ex 9.9 and have been looking at the Wheels Manufacturing PF86/92 which also comes in with Ceramic bearings
So the first question is will this fit my frame as I'm a little confused over the newer standards and secondly is it worth getting the ceramic bearing version?
Also any feedback on these BBs as an alternative to Hope or a suitable alternative to either?
Thanks 🙂
Posted : 08/02/2020 1:39 pm
what crank to you have?
Posted : 08/02/2020 1:41 pm
If it'll fit, I'd be looking at the cane creek hellbender BB.
Posted : 08/02/2020 1:43 pm
Assuming it is PF92 rather than Trek’s own (PF95?) you’d be better with this one as it threads together to ensure bearings are parallel and doesn’t creak.
https://www.freewheel.co.uk/wheels-manufacturing-bb8692-outboard-abec-3-var8692out
Posted : 08/02/2020 2:26 pm
Yes, definitely PF92 and not the Trek own standard. Running XT M8000 cranks.
I did look at the Hellbender but the spindle size was wrong iirc.
Not creaking is good, do you still need a press to fit initially?
Posted : 08/02/2020 2:54 pm
The wheels manufacturing thread together bb has been pretty trouble free on the other half’s bike for over 5 years. The odd check to make sure it’s still snug. Bearing life is more or less comparable to what I tend to get out of normal shimano bbs but does depend on which bearings you refit.
Happy enough with it I bought one for my cross bike.
Posted : 08/02/2020 6:28 pm
