I've just stripped a thread on the chainring bolts on my M7000 cranks so I am on the hunt for a replacement..
I need 175mm, 34t preferably Shimano.
Boost frame, and chainring to work with 1/8" Singlespeed chain.
Would the M7120, 12sp version work with 1/8 chain or is there something on the tooth profile that means it wouldn't play well together?
Posted : 11/08/2024 8:39 pm
I've got 12 speed Shimano XT 175mm cranks that came off my Occam when I put 165s on.
Would they be any use?
Posted : 11/08/2024 10:19 pm
Apologies if I've basically repeated your question back to you ๐
Posted : 11/08/2024 10:22 pm
You should be fine on a single speed chain, new chainrings are a little more expensive than 4 bolt rings but not too painful.
7120 might be boost or superboost rather than normal spacing, not sure
Posted : 11/08/2024 11:02 pm
Thanks, will see what I can find.
Posted : 11/08/2024 11:35 pm
