removing the rocker...
[Closed] removing the rocker pivot bearing on a top fuel
 mrmo
Has anyone tried to replace the top pair of bearings on a trek top fuel, i am currently trying to get the bearing out and can't see how.
The arrangement is a pair of bearings and a sleeve between, normally i would tap the sleeve out of the way allowing a drift to be used to tap the bearing out, but the sleeve doesn't move enough to allow a drift to be used to move the bearing?
Is there another way?
Posted : 25/04/2011 10:40 am
