Is the above possible? Presumably it's a bodge affair. ( should have got xt's i know)
Posted : 29/11/2009 9:45 pm
Are they not held on with two tiny screws? if so remove and silicone the holes up.
Posted : 29/11/2009 9:46 pm
seem to be an integral part of the design ie there moulded into the main part of the shifter. I suppose a cut and silicon job may work.
Posted : 29/11/2009 9:48 pm
Why do people do this? โ
To put them on the other side of the brake lever.
Posted : 29/11/2009 9:49 pm
yep.
Posted : 29/11/2009 9:51 pm
thanks for the replys. seems a cut a silicon affair.
Posted : 29/11/2009 9:57 pm
SLX come with a little disc (behind the indicator assembly).
Posted : 29/11/2009 10:24 pm
do xtr shifters have windows?
Posted : 29/11/2009 11:39 pm
Did you throw the indicators away when/if you did this? I broke my indicator when I replaced the cable on my 9spd rear Deore shifter and I begrudge buying another shifter when it's sweet apart from the lack of indicator. ๐ก
Posted : 04/01/2010 11:35 pm
