Removing seized bot...
[Closed] Removing seized bottom bracket cups
I've just attempted to remove my GXP bottom bracket and it appears to be seized despite liberally applying copper grease when I installed it. Any advice for removing it? I thought of applying gentle heat to the BB shell but am worried about damaging the bearings or spacers.
Posted : 28/01/2009 10:32 pm
PlusGas, and lots of it. Blast from the outside and also down the seattube/through the bottle cage mounts (if applicable). Slosh it round, let it soak for a while, repeat, and then removing it again.
Don't use WD40: it's not a "proper" penetrating oil hence it's rubbsih for freeing seized threads.
Posted : 28/01/2009 10:34 pm
Okay, thanks. I'll get some tomorrow.
Posted : 28/01/2009 11:12 pm
Rather than heating the BB shell you could try cooling the BB itself using a pipe freezing spray kit, available from B&Q etc. I successfully used this to remove a stuck pivot bolt on my FS bike. Good luck.
Posted : 28/01/2009 11:19 pm
you are turning it the right way as one side goes the wrong way Clockwise to undo?
Posted : 28/01/2009 11:28 pm
A nice sharp blow from a nice dead-blow type hammer I find does the trick.
(You know the type the plastic/rubber covered ones)
Posted : 28/01/2009 11:33 pm
 WTF
Halfords sell similar stuff to freeze spray but I think this has some penetrating oil in it also.
[url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_274625_langId_-1_categoryId_165594 ]Halfords link.[/url]
Posted : 28/01/2009 11:37 pm
Slight hijack - As I'm just about to install some outside bearing cranks (for the first time) any recommendations on what I should use to grease the threads?
Posted : 29/01/2009 11:45 am
Bimbler ...copper grease
Posted : 29/01/2009 11:53 am
