Never had a problem with just a spanner in the past but the 29er RS lower bolts are recessed to far into the fork.
Is there a tool I can use to remove the lower bolts without having to purchase a complete socket set?
halfords sell individual sockets if that's any help?
Buy a socket on it's own (need a deep one) or cheap option is a box wrench (or set of, normally very cheap)
Individual socket and my molegrips should then suffice. Cheers guys
Hmmm, perhaps this is the excuse I need to purchase a complete socket set.
Deep 6 sided socket and extension bar to tap with rubber mallet. ๐
Probably not - as LoCo says you'll probably need an extension bar too. If you're buying a socket set with this task in mind, they won't all fit - my 1/2" drive set won't do the job, but a mate's 3/8th teng set will.
If you're doing it on the cheap, get a box spanner:
[img]
[/img]
Box spanner, that's the fella!!
