Little experiment to see if this will stop the fork lifting too much.
So ... all you experts out there ... what do I do and in what order? In simple terms for a bimbo please!
Thank you so much. ๐
C_G
raising ineptitude to a new level)
Do you own a hammer?
Yes but I did attempt this once before. I'm useless. ๐ณ
undo stem bolts
undo and remove stem cap
lift stem
remove spacers
replace stem
put spacers on top
put stem cap on top
tighten stem cap bolt just enough to stop the headset knocking
line up stem
tighten stem bolts
test ride
Did I miss anything? I'm tired and ready for bed.
Thanks Onzadog. 8) Night night!
Doh, too slow. Nighty night X
Onza is correct. Put the spacers back on the top. Only when you are sure you are happy with it should you cut the steerer tube down, that's usually an act of no return.
Just a wee update ...
Job done, bike tested and everything OK. ๐ Not cutting steerer.
Thanks again for your help STW'ers!
