Removing headset cu...
[Closed] Removing headset cups...where/how do I clamp the frame?
Ok, so I've got one of those splayed headset remover tools and have removed headset cups before but where should I be clamping or holding the frame?
I'm always worried that bashing out the headset cup is going to put stress on the headtube/down tube/top tube joint. Especially for carbon.
Any thoughts?
Posted : 30/05/2013 7:20 pm
Hold the headtube between your knees
Posted : 30/05/2013 7:45 pm
A
As above just hold the frame and tap it out it wont be that tight
Posted : 30/05/2013 7:49 pm
I clamp mine by the seatpin in a work stand. The bike will (imo) rotate before harm comes to it that way. Only experience is steel and alloy.
I find a carefully wielded lump hammer (2kg) is the correct driving device. One sharp tap is all it takes remembering to recoil the hammer not follow through onto the head tube!!
This advice may not be carbon safe or in fact safe at all but has worked for me.
Posted : 30/05/2013 7:51 pm
I use my knees, and a dead blow hammer.
Posted : 30/05/2013 8:17 pm
Just replaced one this afternoon. As Mr Dweller said, clamp it in a workstand. A swift blow with a hammer using a suitable drift works well. The stand rotates and damps some of the strike but you should get it moving.
I had to carefully grind the fork crown race cup off with a dremmel as I could not shift it. As I got close to the fork tube the race split and came off easily.
Posted : 30/05/2013 8:49 pm
Thanks chaps, confirms the sort of methods I've used before....thinking back I had carbon handlebars dangling from the brake hoses and gear cables before now, unfortunately directly below the headtube, as the remover whizzed its way through removing the headset and a chunk out of the bars ๐Ÿ™
Posted : 30/05/2013 8:57 pm
