Removing Freehub Bo...
[Closed] Removing Freehub Body from Chris King Hub - HELP
3 Users
All the instructions say is to pull away from hub - a vid I've seen on the net says to turn slightly anticlockwise whilst doing so.
I've done both and the freehub body doesn't budge.
Now, I've given it a pretty good pull and am concerned that if I go at it much harder I might damage something.
Please advise.
Posted : 01/06/2009 12:16 pm
Bump
Posted : 01/06/2009 4:04 pm
The axle is out I assume?
It can take quite a tug and usually comes off with a pop/click
Posted : 01/06/2009 4:48 pm
Undo the axle, remove non drovside part of the axle, give the freehub a twist anticlickwose and tug. Sometimes you have to give it fair old pull. Can't think of anything you could damage by pulling too hard!
Posted : 01/06/2009 5:01 pm
Hi Anthony,
Yes axle out.
I've already given quite a tug - just a bit worried as it's not giving at all - will have another go - might need two people!
Posted : 01/06/2009 5:12 pm
Cheers sheldona
going to give it a go now - will report back
Posted : 01/06/2009 5:14 pm
mmmmmmmm......
well had an interesting tug of war with my lad but unfortunately no joy.
I note that in the service vid -
http://video.google.com/videoplay?docid=-2732641701589174520
- the chap has a special tool for gripping the freehub body. I'm loosing grip before I can exert enough pulling force.
Posted : 01/06/2009 5:50 pm
