...405 ๐
They lasted the first wet ride in the lakes and now look pretty grim after 6 months! Hence the new frames are painted.
Any ideas anyone? The anodising is tough as old boots but don't want to flatten the finish.
Still a fantastic bike all the same!!
PB
Nail varnish remover. Apply, soak, rub off with a soft cloth.
hot water?
pretty much any solvent will do the job and leave the anodising alone, to effect the anodising you need a caustic (like drain cleaner).
So acetone (generally found in nail varnish remover, but the cheaper version without moisterisers), nitromors etc should all dissolve the glue.
YOu might get away with a fingernail and a hair dryer if you really heat it up (i dunno what type of decals they are).
Cheers guys, will have go.
Thanks
Plumbob
