Removing bodge tape...
[Closed] Removing bodge tape from ghetto'd rim?
Whats the best way to remove bodge tape from a ghetto'd rim after its been on fro a couple of years, the stuff is just falling apart and leaving all the sticky residue on the rim !!
Posted : 01/03/2017 11:33 am
Peel and pick off the tape, then remove residue with white spirit/petrol/WD40.
Posted : 01/03/2017 11:42 am
 mm93
Get it really hot with a hair dryer.
Posted : 01/03/2017 11:45 am
 nach
Isopropyl on a rag got it off quickly for me.
Posted : 01/03/2017 11:48 am
Man what a pain in the arse it is, its just flaking off bit by bit and leaving all the white sticky stuff which is stickier than a sticky thing in sticksville!!!
Posted : 01/03/2017 12:00 pm
+1 for a bit of heat. Hair drier, paint gun (used carefully) or even hot water and a scourer
acetone or nail polish remover probably best for gooey stuff removal.
Posted : 01/03/2017 12:19 pm
just leave it on and put fresh over the top of it.
Posted : 01/03/2017 12:23 pm
If it's gorilla tape, you're going to have a bad time. I tore off as much as I could, then used quite a lot of petrol to melt the glue. Then I think a scotchbrite pad or an old tshirt to get the glue/tape gunk off (paper towels just stick to the goo and fall apart). It was rubbish tbh.
Posted : 01/03/2017 12:57 pm
It does look like some sort of gorilla tape.
Posted : 01/03/2017 1:05 pm
Apparently Semen does the trick, that wot Flashy says.
Posted : 01/03/2017 1:43 pm
You can buy pure acetone from the Boots pharmacy counter, you just have to ask for it. It cost £1.60 for a bottle.
Posted : 01/03/2017 1:49 pm
I've used paint thinners in the past with good results, but use it in a well ventilated space away from any sources of ignition.
Also you could try Autoglym bug and tar remover, as it works quite well.
Posted : 01/03/2017 2:21 pm
If it's gaffs tape the best thing to use is petrol
I find after a few years just the top shiny layer peel off, the petrol breaks up the adhesive so all the strands will come off, then hose it all off after
Posted : 01/03/2017 3:41 pm
