Removing a 2005 Lef...
[Closed] Removing a 2005 Lefty Max steerer
Hi all
I'm replacing my lefty with a set of Fox float 32 140mm RLC forks and have 2 questions:
1. How do I remove the steerer tube at home, tried LBS but they can't help so need DIY way of doing it
2. what headset to use. been told by hope theirs would work but CRC states it doesn't. Has anybody used one? what else is there?
cheers
Posted : 28/10/2009 12:58 pm
for Q 1
Remove stem
Undo fork crown bolts
Whack steerer with rubber mallet
Jobs a goodun'
Posted : 28/10/2009 1:06 pm
1. once you have remove the stem + upper crown it will be free. You'll probably have to whack it a bit though as it's a tight fit in the headset cartridge bearings.
2. The headtube is 1.5" diameter. However, depending on the model/year of the frame some 1.5" headsets may not fit as the cups are too deep a fit into the frame. This generally isn't an issue on newer frames though.
I fitted a superstar 1.5->1+1/8 headset to my '06 rush no problem.
Posted : 28/10/2009 1:08 pm
FSA do a cannondale reducer headset, as do woodman I think. Otherwise use reducer cups from BETD (among others) and a 1-1/8th headset.
Posted : 28/10/2009 2:29 pm
You'll need the equivalent of the Cannondale black rubber dildo thing to get the steerer all the way through, and the chances are you will have to hit it pretty hard.
Posted : 28/10/2009 3:23 pm
BLACK RUBBER DILDO THING???
technical is that?
Posted : 28/10/2009 4:20 pm
I dunno what he's on about. I don't have and haven't ever used a black rubber dildo thing, even when removing my lefty!
Posted : 28/10/2009 4:27 pm
I know what he means about hitting it hard though, tried before and gave up trying to get past the lower bearing, any tips?
the bike is a 2005 five model so should be fine?
Posted : 28/10/2009 4:32 pm
I don't remember having to hit mine particularly hard to be honest. Just a few whacks with a bit of wood.
Posted : 28/10/2009 4:34 pm
thats what i thought, just drop it through the head tube and tap?
thanks for the feedback by the way
Posted : 28/10/2009 4:36 pm
The rubber dildo thing is the correct long drift thing that you are meant to use to remove the steerer, or at least get it passed the lower bearing.
Posted : 28/10/2009 9:19 pm
Thanks to everyone who offered advice.
It went fairly smoothly, just need to remove the headset itself now
Posted : 29/10/2009 9:22 am
More hammering - this time involving a big screwdriver ๐Ÿ˜›
Posted : 29/10/2009 1:02 pm
