Just had a 10mm spacer put into my Fox Float 140mm to reduce the travel to 130mm. Should the overall length of the fork have been reduced as a result? That was the plan, as I found the 140 mm a bit "noodley" when climbing. I have just measured the stantions and it's still 140mm. Any idea STW?
Posted : 09/05/2014 8:41 pm
Did you measure the stanchions before lowering them? Fox would have around 150mm exposed for a 140mm fork iirc
Posted : 09/05/2014 8:44 pm
I didn't measure them to be fair - schoolboy error.
Anyone else ?
Posted : 09/05/2014 9:01 pm
I ride a Yeti ASR 5, if that helps at all, but don't see why it should.
Posted : 09/05/2014 9:09 pm
Yes, travel reducers in Fox forks shorten the overall length of the fork when it is fully extended.
They make no difference to the fully compressed length.
Posted : 10/05/2014 12:05 am
