Recycling brake flu...
Recycling brake fluid
When bleeding my Hope brakes, is there a reason why I can't bleed the used oil straight out of the caliper and back into the container that stores the new oil?
Posted : 02/01/2026 11:34 pm
DOT fluid is hydrophilic (absorbs water).
Brake boiling/fade can be caused by water in the fluid boiling at 100C Vs whatever the much higher boiling point of DOT is.
I have always discarded DOT.
Someone can no doubt offer a more technical explanation but old DOT fluid - bad.
Also dirt etc in the fluid.
Posted : 02/01/2026 11:54 pm
There is the possibility that the fluid is contaminated with moisture as DOT 4 & 5 fluid absorbs it, thus lowering the boiling point. Recycle the fluid at your local tip.
Posted : 02/01/2026 11:56 pm
I mean it's basically sloppy seconds, why would you want to reuse it?
Posted : 03/01/2026 12:04 am
It works like that with mineral oil, but DOT chemically absorbs water so it doesn't sit seperately. DOT has a 'dry' boiling point and a 'wet' boiling point, but both are much higher than 100°C.
Posted : 03/01/2026 6:25 pm
Thanks all
Posted : 03/01/2026 10:30 pm
