Recommendations for...
[Closed] Recommendations for pipe cutters for bars and steerer tube?
Thanks for any recommendations in advance
Posted : 20/11/2021 1:21 pm
Use a saw. Pipe cutters don't leave a good finish.
An old stem makes a good cutting guide.
Posted : 20/11/2021 1:22 pm
Yep. Hack saw is faster than dealing with the nasty edges that stop the headset slipping on etc.
Learning how to cut straight with a hacksaw is pretty handy too.
Posted : 20/11/2021 1:26 pm
Thanks - symptom of watching people use fancy tools on youtube.
Is there a tool to guide the saw, to get a nice square cut? Can just use a basic file to take any burrs off.
Posted : 20/11/2021 1:35 pm
Two headset spacers and some duct tape for steerer.
Two Lock-On clamps and some duct tape for bars
Posted : 20/11/2021 2:33 pm
Got a Topeak cutting guide, as i'm using it day in, day out. Does a decent job when new, but they do wear out if using them as much as I do. Would I bother for occasional use? Nope, not worth it, just scribe around a spacer resting on the stem at the required height, and cut with a hacksaw (24t for ally, 32t for steel), and file to finish.
Posted : 20/11/2021 3:37 pm
I use a decent hacksaw and a Lifeline cutting guide - in fact I used it today for my new Lyriks. The guide is £15 well spent - used it on steerers and seatposts so far.
https://www.wiggle.co.uk/lifeline-saw-guide?lang=en&curr=GBP&dest=1&sku=105205762&utm_source=google&utm_term=&utm_campaign=&utm_medium=&gclid=EAIaIQobChMI4dSTuZin9AIVRvlRCh2pMwlTEAQYASABEgJIS_D_BwE&gclsrc=aw.ds
Posted : 20/11/2021 3:52 pm
 poah
use a cutting guide and hacksaw.
Posted : 20/11/2021 3:57 pm
These are good for cleaning up steerers, but yeah a file will work too.
https://www.icetoolz.com/ec99/rwd1111/product.asp?prodid=16B1
As mentioned above, I used to just use an old stem as a guide. A long one gives good purchase for your foot so the fork doesn't move much when sawing! But there are plenty of guides around.
Posted : 20/11/2021 4:50 pm
I just wrap a bit of paper round it and follow the edge of the paper.
Posted : 20/11/2021 4:59 pm
Pipe cutter has always worked well for me - not sure what problems I should have had?
Posted : 20/11/2021 5:47 pm
Ditto for me - always had success with a pipe cutter. Tape up first, and file the sharpness off after. Blade needs to be good and sharp though.
Posted : 20/11/2021 6:14 pm
Sorry forgot to say - mine is just a generic one off eBay - cost a few pounds…
Posted : 20/11/2021 6:17 pm
Pipe cutter then finish with a Ridgid 223S reamer.
Posted : 20/11/2021 6:20 pm
Been using a pipe cutter for years, never had a problem.
Posted : 20/11/2021 6:22 pm
Cheap Silverline pipe cutter for bars, hacksaw & a Jubilee clip as a guide for steerers. Clean up with a fine file.
Posted : 20/11/2021 8:14 pm
walleater
As mentioned above, I used to just use an old stem as a guide. A long one gives good purchase for your foot so the fork doesn’t move much when sawing! But there are plenty of guides around.
Are you some kind of contortionist?
Posted : 20/11/2021 8:29 pm
I’ve got a new PRO (Shimano brand) steerer cutting guide tool spare - brand new and carded.
DM me if you’re interested? £5 plus whatever it costs to post.
Posted : 20/11/2021 9:22 pm
A sharp new hacksaw blade, a piece of tape to guide me, take it nice & steady, worked fine. After I measured it twice, & corrected the markings…. I’m sure a guide would be lovely, but I fit new forks once in a blue moon.
Posted : 20/11/2021 9:45 pm
I used to use a hacksaw and guide, but I now use a pipe cutter and have an old reamer that I ‘borrowed’ from my dad’s workshop (he had many). Not sure what brand mine is as it was a spare one my dad had lying around (so either cheap from screwfix or really expensive). They’re so easy to use and if it’s a sharp one (mine is) then they leave a really clean cut.
Posted : 20/11/2021 9:49 pm
@sillyoldman if the OP doesn't take you up on it, I will please.
Posted : 20/11/2021 9:50 pm
Thanks all for the input! Appreciated. Plenty of options and I like the guide approach best.
@sillyoldman thanks I’ll DM you now. Cheers too @Jordan
Posted : 20/11/2021 9:59 pm
Pipe cutter has always worked well for me – not sure what problems I should have had?
People often bulge the tube either side of the cut when using a pipe cutter.
Posted : 20/11/2021 10:54 pm
If you bulge the tube then they’re not using it properly, you’re supposed to gradually tighten it as you go in small increments.
You can’t fault a tool for not working properly if it’s being used by a complete tool.
Posted : 20/11/2021 11:20 pm
I just run a piece of tape round as a guide then cut a section, turn it a little in the vice, repeat until I have a nice even groove/cut.
Posted : 21/11/2021 6:47 am
 st
I own a proper cutting guide and subsequently bought a silverline pipe cutter, I've used both for cutting a steerer and prefer the pipe cutter, go slowly and it works perfectly and you're far less likely to get metal bits in your fork seals
Posted : 21/11/2021 8:43 am
I bought one of these for cutting stainless steel kitchen rails, also works a treat on bars etc. and covers 5-35mm
Not cheap but super accurate and easy to use. I have a clamp on cutting guide, but actually now prefer the tube cutter.
https://www.ffx.co.uk/product/Get/Ridgid-Rid29963-0095691299635-35S-Stainless-Steel-Tube-Cutter
Posted : 21/11/2021 10:05 am
I use a pipe cutter too - the same Irwin one as mentioned above. Far less faff than a hacksaw.
Posted : 21/11/2021 2:35 pm
I think the entire reason for changing stem standards, was to create a limitless supply of worthless old stems to use for cutting steerers.
Posted : 21/11/2021 6:05 pm
Just get the grinder out!
Posted : 21/11/2021 6:49 pm
Pipe cutter for bars and hacksaw and guide for the steerer. Probably not the answer you wanted!
You get a cleaner edge when using a pipe cutter if you use it gradually rather than clamping it down double tight. Even then there will still be a tiny bit of filling/reaming if you are bothered about smooth edges. Some pipe cutters have a built in reaming blade/triangle spike.
I use a Monument pipe cutter because that's what I've got for cutting pipes. For cutting actual pipes ratchet cutters are handy things to have!
Posted : 21/11/2021 6:50 pm
