Recommendations for...
[Closed] Recommendations for Chain Lube for Road Bikes
I switched to Putoline for MTB applications years ago, but I'm not using that on my road bike!ย  I have been using various wet lubes that I had left over, but as might be expected, these attract a lot of gunk and filth in a short time.ย  I know there will be something lighter that does the job and doesn't get so dirty so quickly, any recommendations?
Posted : 30/05/2018 10:00 am
Why do you not want to use putoline for a road bike?
Posted : 30/05/2018 10:01 am
Smoove. I was a putoline user in the winter, but since moving to smoove, I've not felt the need for putoline.
Posted : 30/05/2018 10:12 am
Cookeaa - because I want something that's light and cleaner, so if I need to pop wheel out or handle it for any reason, I don't end up looking like I've been down the pit!
Posted : 30/05/2018 10:15 am
Finish Line "Dry"ย PTFEย lube and Pedros Ice Wax both stay clean and gunk free.
Posted : 30/05/2018 10:35 am
Smoove.
Does pretty much what it claims.ย  Been using it on CX/Gravel bike.
Posted : 30/05/2018 10:45 am
 aP
My current favourite is Wickens and Soderstrom No3. It seems to last well and doesn't pick up a lot of gunk.
Posted : 30/05/2018 11:20 am
also using W&S No 3 here which works very well. For dry conditions Pedrox Ice Wax is one of the cleanest and lasts long if it stays dry...
Have a bottle of W&S No 5 to try next !
Posted : 30/05/2018 11:45 am
 cp
Big fan of purple extreme.ย  Just make sure it's had a good 12-24 hours after application to dry out otherwise you get a black mess if used straight after lubing.
Posted : 30/05/2018 11:47 am
fenwicks stealth for me, tidy lube with minimal mess.
Posted : 30/05/2018 11:50 am
Thanks, All ๐Ÿ™‚
Posted : 30/05/2018 12:42 pm
FinishLine Dry for me, nothing better.
Posted : 30/05/2018 1:18 pm
Putoline the chain then once it is back on the bike spray a bit of wd40 or similar onto a cloth and run the chain thru it - takes allthe excess off the outside where you don't need it but leaves it all in the rollers where it is needed?ย  thats what I do
Posted : 30/05/2018 1:34 pm
Sawchain oil.
Posted : 30/05/2018 2:18 pm
I useย muc off ceramic dry lube c3. Ive not found anything better.
Posted : 30/05/2018 2:23 pm
Rock n roll gold or extreme
Posted : 30/05/2018 3:43 pm
Wurth motorcycle chain wax in a massive tin.
Posted : 30/05/2018 4:10 pm
Squirt. Lasts well, not messy.
Posted : 30/05/2018 7:42 pm
