Basically the problem is I can't get the E13 XCX I bought a while ago to work properly. No matter what I try the the chain ring, with out the chain fitted, always rubs/grinds against the outer guide. I've tried different cranks (Shimano Deore and SLX, and a Midlleburn RS7 (with 3 different BB axle lengths)) and all give the same result. The frame is a Cotic Soul with a 73mm BB shell and the guide is always set as close as possible towards the crank.
Can any one recommend something that actually works?
Top only? MRP 1X is very good.
Yep, top only is what I'm looking for.
just bought one of [url= http://superstar.tibolts.co.uk/product_info.php?cPath=56&products_id=475 ]THESE[/url] for C456 1x10 build.
used it twice and hasn't dropped the chain, although i think it does need adjusting.
mucho cheapness compated to the XCX ones!
Steady on! Recommending a Superstar product will have people wanting to burn you at the stake!
I too run the SS one on my Five. Has dropped a chain once when I backpedalled to jump on the bike. Big deal. Its cheap and it works although when I can be bothered I'll probably get a Straitline Silent Guide.
I've got the SS one as well on another bike, it's perfectly decent. Backplate isn't that strong- bends a bit easily- and the cage is a little bit fiddly get it absolutely right (I reckon it's too wide at the top and too narrow at the bottom). But it's good value and it does the job. Also, sometimes cheaper under the other brands like MParts.
But the MRP one is quite a bit better. Stiffer, easier to set up, better adjustment, and just seems to control the chain better. But, it's more expensive.
I've had an XCX and an MRP. I had the same issues as the OP with both, but the MRP was much easier just to add a spacer between the backplate and guide. The XCX eventually worked after adding thin washers between the 2 halves of the guide.
What about the things Cy @ Geeky Towers is knocking out?
They work for singles, doubles and triples.
[url= http://www.cotic.co.uk/news/ ]Scroll halfway down the page
[/url]
[url= http://www.bionicon.com/ac/c-guide-v02 ]link[/url]
I wouldn't use only a c-guide for a single ring setup - it's more a tensioner than a guide.
