Recommend me a towb...
[Closed] Recommend me a towbar mounted cycle carrier
Sorry if it's been done before-
Finally had the towbar fitted to the new motor and looking for a towbar mounted carrier. The roof is too tall for me to reach with the bikes and I needed the towbar anyway. Mostly I'd be carrying 1 or 2 bikes but does it make sense to get a 3 or even 4 bike rack just in case. Was looking at the Thule Rideon 9503
Posted : 18/11/2010 7:38 pm
We've got that model, does the job just fine.
Posted : 18/11/2010 7:44 pm
 TomB
Highly recommend [url= http://www.roofbox.co.uk/scripts/rbvehsel4_tab.php/all-products/buzz_rack_buzzrunner_3_bike_wheel_support_rack_no_brp103/Qx%40w%2C6M4PHS%2CZGenkQvENtF2sA ]this BUZZ RACK[/url] 3 bike carrier. Very solid, easy to fit and remove, and tilts down to provide access to boot of my people carrier.
Very pleased so far, normally carry 2 MTBs and a kids bike on it.
Posted : 18/11/2010 7:50 pm
Mate of mine has this one:
Excellent bit of kit.
Posted : 18/11/2010 7:53 pm
 br
[i]Thule Rideon 9503[/i]
I've had this one for over 5 years now, but if buying again I'd go for this:
http://www.roofrackshop.co.uk/bike/thule-947-euroway-bike-carrier.htm
The Rideon struggles a bit with 3 bikes on, its never failed, but...
Posted : 18/11/2010 8:00 pm
That Pendle one looks interesting and there are only round the corner, don't know if they have a shop at the factory, might ring 'em in the morning.
Posted : 18/11/2010 8:06 pm
See, I can't quite get my head around some of these designs.
The Pendle one I put up above slots into 2 tubes mounted to a plate bolted behind the towball. Extremely secure.
Most other types I see including these Thules look like they literally just clamp onto the towball itself. Is that right? Surely not? If so how do they not just move around on the ball with the weight of 3 bikes hanging off them? Just clamp them up really ****ing tight?
Posted : 18/11/2010 8:07 pm
rideon 9503 is excellent for 2 bikes.
3 full sussers is a bit of a head scratcher, but is doable.
Dave
Posted : 18/11/2010 8:08 pm
Yes they do just clamp round the towball. It's not difficult to get them tight enough that they don't move.
Posted : 18/11/2010 8:10 pm
www.aistoncycleracks.co.uk like the pendle in the picture above but better in every way and cheaper. I've owned both and a thule and would now only use the Aiston. The website is very basic but the guys really good on the phone.
Posted : 18/11/2010 8:11 pm
I have the Thule 9503, as above, and have used it for a couple of years now, no issues at all, three bikes, 500mile round trip/weekend away, various races, bike events, no movement in it even at 70(ish) on the motorway. Only additions I've added are the lock to lock it onto the towbar, and a length of pipelagging, which I put on the forks, if I'm carrying more than one bike, just to stop any metal on metal contact between the bikes. Got mine for the ride side of £100 from Halfrauds in a sale.
Posted : 18/11/2010 8:15 pm
If you have a swan neck / removable towbar then the only option is the clamp on ball type. Scary principle, but they do seem to work!
The Thule 9503 is a very capable rack, good value, but personally found it fiddly to attach bikes.
Posted : 18/11/2010 8:16 pm
 br
[i]Most other types I see including these Thules look like they literally just clamp onto the towball itself. Is that right? Surely not? If so how do they not just move around on the ball with the weight of 3 bikes hanging off them? Just clamp them up really ****ing tight? [/i]
No not really, all you need is to clamp around the base and then have a 'cup' on the top.
Thule.
Posted : 18/11/2010 8:17 pm
Good point Biscuit and something I hadn't actually thought about. So what happens if it doesn't grab hold of the ball tight enough, first bump I go over will it slip down? Surely there's a stop or something?
Posted : 18/11/2010 8:18 pm
Smarty, where are you based? I'm in South Wales, between Afan and Cwm Carn, you are more than welcome to come have a look at my Thule fitted, and see for yourself how secure it is if you like
(Edit; and no it's not for sale)
Posted : 18/11/2010 8:27 pm
Cheers ron but it's a bit of a trek, I'm in sunny Pendle area.
We have a saying round here, 'if you can't see Pendle Hill it cos it's raining and if you can see Pendle hill it's about to rain' 🙄
Posted : 18/11/2010 8:39 pm
thule pro 903 is good, but the wiring for the lighting is rubbish. Apart from that it's a great rack, no movement with 4 13kg bikes on, and it's one of the ball clamp types.
Posted : 18/11/2010 8:49 pm
Doesn't seem like a very good solution to me but it obviously works.
Posted : 18/11/2010 8:51 pm
Thule Euroclassic. Expensive but quality bit of kit and fully tilts at flick of a lever to let boot open.
Posted : 18/11/2010 8:52 pm
+1 for the Aiston rack referred to by Steveh.
Posted : 19/11/2010 12:29 am
Another Thule 2-bike 3ball-mounted user here; so easy to use. On and off in half a minute, and the clamping mechanism has a lock. Has been utterly reliable in over a year. Best feature is that it tilts to allow full access to the boot, but suspect the larger (3+ bikes) may not do it?
Posted : 19/11/2010 7:44 am
I've got a 909 Euroclassic G5, and can't fault it apart from the price! It's rock steady at speed and allthough I've never yet used the 4th bike adaptor, it's fine with 3 on it.
It's one of the clamp on the tow ball affairs and it tightens up dead easy - it's either on or off, you can't get it wrong (tempting fate somewhat).
They do tilt when loaded, even with the 4th adaptor.
I don't trust the lock on the clamp though, I use an extra lock to lock the bikes together, and if parking up somewhere, a cable through the bikes and into the back of the car.
Posted : 19/11/2010 9:54 am
We've been using an Atera Strada for a couple of years now.
It's been faultless. Very stable and the way it slides out on rollers is brilliant.
Oh and we went for the three bike version even though there's normaly only two bikes on it. Gives you another option and there's a bit more room between the bikes.
[url] http://www.roofbox.co.uk/scripts/rbvehsel4_tab.php/car-accessories/atera_strada_dl_3_to_4_bike_carrier_uk_lights_no_ar2603/njNA_v1HqTo9~w7HCO3kxz3uBtkB%2C~4RYoJEYzTmI [/url]
Posted : 19/11/2010 9:56 am
i have a maxraxx which is pretty good. i wanted a rack that left the towball free for towing.
Posted : 19/11/2010 10:29 am
Euroclassic here too. Picked it up mega-cheap in a sale but having owned it would willingly pay closer to full price if I had to buy again.
I'm sure they are available at reasonable discounts anyway, most Thule stuff is.
Posted : 19/11/2010 10:37 am
Hi all,
I am also looking at a Thule towbar mounted carrier and am undecided between the Ride On post/strap style and the arm/clamp style.
I will be carrying a mix of bikes including my full suss with no top tube and a carbon hardtail.
Does anyone have experience to offer on the best style of rack for a mix of bike shapes and delicate carbon tubes.
Thanks all, Dave
Posted : 19/11/2010 10:20 pm
We've been running the Thule euroclassic for maybe 5 years now. It's covered thousands of miles all over uk and europe whith ease. Usually carrying 3 bikes but occasionaly 4. I did strip a thread on one of the clamps once but replacement was easy from Thule, they asked for a donation to charity instead of charging for the part. Highly recommended, maybe a little heavy but then it does have to cope with up to 4 bikes!
Posted : 19/11/2010 10:47 pm
