Recommend me a toug...
[Closed] Recommend me a tough sidewalled tyre for tubeless
As per title.
With all this dry weather, I've been running a Larsen TT on the rear of my Meta 5 and a single ply supertacky Minnion on the front. Rims are Flows with yellow tape and Stans fluid.
After about the fifth ride and probably less than 150 miles total, I've ripped the sidewall to beyond the magic healing capability of the fluid.
(Edit:It's the TT on the rear that's ripped)
Last time I did Garburn before I went tubeless, I had 3 pinch flats in one day. Since tubeless - None, so I'm not going to abandon tubeless after one small setback but I could do with something more substantial in the sidewall department for the back end.
Typical riding; Lakes, Calderdale, etc.
Want something fairly fast rolling and not too heavy
Moon on a stick?
Posted : 27/05/2010 12:38 pm
"proper" ust tyres are thicker-walled
ust rubber queen seem OK (have a kind of "textured" wall too, whether it helps I dunno). Not sure it (2.2) is massively grippy but reckon fine for the back
Posted : 27/05/2010 1:14 pm
Go look at specialized's range of tyres. Best VFM I have found and they are brilliant bits of rubber.
Posted : 27/05/2010 1:19 pm
Yeah, I was thinking it would be either a UST or a dual ply to try next.
I'd probably lean towards a different Maxis tyre as first choice but I'll check out the RubberQueens next time I'm in a shop.
Ta
Posted : 27/05/2010 1:21 pm
Any experience of these on Stans rims? Good fit?
Posted : 27/05/2010 1:23 pm
I usually put holes in UST tyres in between the tread, not the sidewalls.
Have done a Maxxiss Lust and a Conti RQ UST (although I was riding down Cader Idris on a 7" bike that time) - so I'm starting to think it's just an occupational hazard.
Will follow suggestions with interest.
Posted : 27/05/2010 1:24 pm
I run them on olympic rims and they seat easily with a track pump. Pretty much as easy as fitting a tubed tyre. Never had any problems with them. Wont use anything else now.
Captains grip like doodoo to a blanket.
Posted : 27/05/2010 1:25 pm
If you like the Larsen TT, it does come in UST flavour.
Posted : 27/05/2010 1:26 pm
Nothing is invincible.
I would definitely NOT recommend maxxis Ignitor LUST - i know of at least 4 tyres that have failed due to a weak bead, using a variety of tubless methods.
I got a Halo Choir Master UST off CRC for £20 recently and it worked really well up in Scotland last week paired with a 2.4 Rubber Queen up front. Sidewalls feel pretty tough, dunno how heavy it is, good in mud/peat and rock but also seemed to allow me to get sideways when called for too. Well impressed, I think I've found my ultimate combo.
Posted : 27/05/2010 1:32 pm
Ah, I didn't know that. Thanks.
Must be worth a try - Had a quick check on CRC, Ribble & Merlin but they don't seem to stock Spesh tyres. Where from?
Posted : 27/05/2010 1:34 pm
Kenda Nevegal with SWS (Sidewall Shield)?
6 months and still going, compared to Maxxis HR exception series and Bontrager Mud X, both of which I have suffered sidewall cuts. Not too fast rolling though. They seem to have stopped making the Small Block 8 in SWS variety.
Posted : 27/05/2010 1:36 pm
Thanks guys,
I'll check out the Nevegal SWS and the Spesh.
The Halo on CRC is probably worth a shot at that price too. Looks grippier and and will probably need a bit more effort to drive it along but I'll give it a try I think (dusty weather can't last for ever).
Posted : 27/05/2010 1:51 pm
 br
I'm surprised, as I went to the TT on my hardtail after been sick of ripping tyres on the flints around here.
What pressures are you running, and is it the 2.35?
Posted : 27/05/2010 1:55 pm
 mttm
Maxxis are introducing a sidewall reinforcement on selected tyres in their range (they're calling it "exo-protection")- might be worth checking out before going the whole hog and trying dual plys. The dps are [i]very[/i] heavy and only really make sense with gravity on your side. Exo-protection will be available on:
Ardent 26x2.25
- Ardent 26x2.4
- Ardent 29x2.4
- CrossMark 26x2.1
- Ignitor 26x2.35
- Ignitor 29x2.1
- Minion 26x2.5 single ply 60a
- Minion 26x2.5 single ply 3C
From this thread [url= http://forums.mtbr.com/showthread.php?p=6602390 ]here[/url]
Posted : 27/05/2010 1:56 pm
as chakaping Ive put holes in a few around the tread, UST Contis and Bontrager TLRs mainly and the bead on my HR LUST has gone all loose.
Where I usually ride its not rocky and UST / TLR seem fine, but in places with rocks I usually hole a tyre, so have tended to put big cunky tyre on with tube last few times I've had day trip away.
Rocks + UST= Jurys out.
Posted : 27/05/2010 1:59 pm
Its a 2.0 at 40psi
I think the issue might be partly due to the Stan's rim allowing so much sidewall to be "in harm's way" on the 2.0
Might have been a bad choice.
More good info, thanks. I'll go looking for some of these. Are they in shops yet?
Posted : 27/05/2010 2:04 pm
 mttm
I haven't been able to find any, but reading between the lines I don't think they're far away. Might just be wishful thinking on my part, though.
EDIT: there's a bit more info and some pics [url= http://brule.pinkbike.com/blog/sea-otter-randoms-part-3-2010.html ]here[/url]
Posted : 27/05/2010 2:07 pm
I tried the Halo Choir master UST, was good initially but it wore out very quickly although as you say for that price it's worth a try.
I'd avoid the highroller LUST - it's the only UST tyre I've managed to puncture.
Posted : 27/05/2010 2:08 pm
 br
Go for the 2.35 TT.
Posted : 27/05/2010 2:13 pm
Thanks all,
Plenty of options there.
I'll do some research tonight.
Posted : 27/05/2010 2:30 pm
Have the same problem (kinda) with flows, except it wasnt ripping sidewalls, its pulling non-tubeless tyres off the rim. The highroller/minion i have has a thinner sidewall than the crossmark i have (all single ply 2.35/2.25, larsons the same?), and the crossmark has a looser bead. Just got an eskar 2.3 2bliss to hopefully sort problem...goes up so easily, only problem is its huge compared to the 2.35 maxxis! Popped the eskar on the front and its pretty good tyre, looking to get a captain 2.2 for the rear.
Posted : 27/05/2010 2:43 pm
+ 1 the Halo Choir Master UST for the rear - cheap and works well
I run a Fat Albert 2.25 UST on the rear which is more money but grippy and tough. Big fan of the FAs - I run a standard 2.35 on the front, setup as ghetto tubeless. Not been as impressed with Maxxis range myself.
Posted : 27/05/2010 3:14 pm
-1 Specialized, the tyre walls are made of paper!
I stuck a Geax on the front of mine a couple of weeks ago, looks pretty thick skinned and was a right b*****d to get on.
Posted : 27/05/2010 3:44 pm
Lots of people seem to say this and it seems to have stuck. I think specialized have changed the control tyres to make them thicker and more rip resistant...the sidewalls of mine certainly dont feel paper thin...time will tell, but its survived 2 rocky rides so far.
Posted : 27/05/2010 4:07 pm
There are two versions of most Spesh TR tyres - Control and S-Works. Would be useful if comments included which one they refer to. The S-works (I've always assumed) are bound to be more fragile, being lighter weight than the Control versions. Certainly a buddy of mine trashed his S-works very easily and he is very easy on components (slow and careful).
Posted : 27/05/2010 5:40 pm
+1 for Specialized tyres here. Running purgatory controls on stans arch without problem.
Posted : 27/05/2010 7:13 pm
 jim
Eskar Controls went up really really easily on 355 rims with yellow tape, can't say the sidewalls seem particularly thin.
Posted : 27/05/2010 7:24 pm
Every time I take the bike out of the garage there's green tyre sealant bleeding out of the side walls, all the way round. And they're the 2Bliss (bloody stupid name, too) ones. Pity, as I quite like the tread.
Posted : 27/05/2010 9:15 pm
