Recommend me a road...
[Closed] Recommend me a road / touring / cx frame with rack mounts
I need to get a larger frame (61-62) and hoped someone might recommend me a frame or bike because the Pompino only comes in a 58 and I am ignorant of what else is good. Steel preferred and with single speed or geared. Nothing too bling though.
Thanks
Rich
Posted : 26/09/2013 9:57 am
 ton
surly disc trucker is very good value.
Posted : 26/09/2013 10:42 am
XL Pinnacle Arkose 3 frame for £110 on Evans. Not steel but it is very tough, i only ever had steel before but didn't regret it. Full rack mounts and full disc. Has a tapered headtube but you can get a hope crown reducer, and I got a cheap set of 29er disc wheels from Merlin. It's a very versatile bike and strong enough for off roading and light touring. I'm 6'2" and the XL fits perfectly, was comfortable on a recent trip to the Alps for a week, even on 100mile Marmotte route slog! Having discs is so much more confidence inspiring than calipers too...and look better. Nice muted frame colour/decals too. I looked at steel frame options and they were heavy or poor value in comparison. Hope that helps...
Posted : 26/09/2013 10:43 am
Salsa Vaya.
Posted : 26/09/2013 11:00 am
I'm currently lusting after a Singular Peregrine. The EBB looks like a really neat solution to chain slack. I'm a bit worried about he positioning of the rack mounts though...
Posted : 26/09/2013 11:10 am
[url= http://www.singularcycles.com/shop/index.php/frames/singular-peregrine.html ]Link[/url]
Posted : 26/09/2013 11:14 am
Have you got a link for the head reducer? I was looking at that frame, but it's 1.25 at the bottom and all the reducers I could find were 1.5. What fork did you use?
Posted : 26/09/2013 11:17 am
If it's a 1.1/8th steerer then the Hope HS136 is the one you want - googling will give you some shopping options. It is actually a 1.5" at the bottom, as I initially used it with an on-one pompetamine disc fork, and the reducer worked perfectly with a standard internal tapered headset (IS 42 upper bearing, IS 52 Lower bearing). I then got a second hand carbon boardman fork for it, and the taper was 1.1/8th - 1.25", and i didn't know there were two taper types. As you say, there are no reducers for 1.25 and it caused me hell, in the end i carefully filed down the inside of the hope reducer. That's the one downside of getting the frame, as the tapered headtube gives limited options for tapered forks with a road axle to crown.
Aside from that, it's a really nice bike to ride and not too harsh at all. It'll build into a light tourer/heavy road bike/cross of about 22-23lbs depending on budget. I'd post a picture of the bike if I knew how!
Posted : 26/09/2013 12:25 pm
Soma Double Cross or a Genesis Day One?
Posted : 26/09/2013 12:28 pm
Thanks for the info. Evans are telling porkies on their site, as they say it's a 1.25!
So my shopping list would be Hope reducing ring, tapered headset (is it integrated or internal?) and a standard 1 1/8th disc fork?
Posted : 26/09/2013 12:47 pm
Registering interest .... That Singular looks awesome ^^^^
Posted : 26/09/2013 1:54 pm
It seems they are, as i've measured and re-measured the bearing seats and internal diameters to get what i needed, Here's an answer from the staff on the Evans website: "Yes, it's a 1 ½ bottom and 1 1/8 top, 45 degree integrated bearings. 42/52mm bearing external diameter with 28.6/40mm internal diameter. 46mm / 56mm head tube external diameter"
That's right,the hope adapter is best, I got an integrated (def no cups, just bearings that sit in the frame) M:part Elite tapered headset from evans (about £30) - the joy of not having to fit a headset! A standard 1:1/8th fork gives plenty of options, like the Salsa Vaya fork or On-one/Planet-X offerings. There's also the option of finding a full carbon tapered steerer fork if you have the budget (Kinesis CXD or a chinese job from Ali express for £110 if you're brave), but they don't have rack mounts and may not be tough enough. Also worth seeing what ebay brings up, I got my BB5 road calipers and fork very cheaply..
Posted : 26/09/2013 1:55 pm
 Sam
That is the V1 Peregrine pictured, the new ones are much lower, just above the disc mount. Out of stock of XL though 🙁
Posted : 26/09/2013 3:17 pm
Surly Trucker, disc or normal at your preference.
Posted : 26/09/2013 3:26 pm
 Sam
Bizarrely I do have lots of XL Ospreys left - can do you a killer deal on one of those if they take your fancy....
Posted : 26/09/2013 3:28 pm
Looks beautiful but I am probably looking something a bit more industrial. Thinking about a surly long haul trucker, has a nice long head tube so could be quite comfy on the back.
Posted : 26/09/2013 8:09 pm
 ton
my bars a 2'' higher than my seat on the disc trucker.....comfiest I have ever been on a bike.
seat is lower now, bars a tad higher
[URL= http://i227.photobucket.com/albums/dd178/20ston/24-06-13disctrucker001_zps0dc571f4.jp g" target="_blank">http://i227.photobucket.com/albums/dd178/20ston/24-06-13disctrucker001_zps0dc571f4.jp g"/> [/IMG][/URL]
Posted : 26/09/2013 8:22 pm
