Recommend a rear li...
[Closed] Recommend a rear light to swap between.bikes
So....have a few bikes, need a rear light that, with the right number of brackets, can be swapped between bikes.
So, I need the light, thinking AAA Batt, around £10 ish, readily available spare/replacement brackets to put on each bike.
Go on,recommend me something.
Thank you
Posted : 02/04/2012 12:38 am
These are good... http://bit.ly/H9PSue
Posted : 02/04/2012 6:25 am
[url= http://www.wiggle.co.uk/?s=knog ]Knog[/url] gecko/skink/boomer are good for that - seem more robust than your average plasticky Crapeye product, with a stretchy rubber attaching mechanism that negates the need for multiple brackets on different bikes.
Posted : 02/04/2012 7:03 am
Another vote for anything Knog. They're designed to whip on and off in about 2 seconds. And appear to be indestructible! I've had a Bullfrog for years. Does the commute on the road bike, then gets covered in crap on night rides. It's still going strong. I keep a set of Frogs in my pack for emergency stayed-in-the-pub-later-than-expected-get-me-home-lights too.
The latest version of the bullfrog appears to be [url= http://www.wiggle.co.uk/knog-skink-led-rear-light/ ]this[/url]
If you drop them, they actually bounce! And you can even get them in pink. What's not to like 😀
Posted : 02/04/2012 8:23 am
If u could change your budget, the exposure flare is an awesome rear light and easy to swap between bikes. Probably much much brighter than the others mentioned above too.
Posted : 02/04/2012 8:56 am
I've just bought my second Electron Backupz 6 LED rear light. No bracket needed, plenty bright enough, never moves, only £10 and the battery lasts for bleeding ages.
Posted : 02/04/2012 7:20 pm
