I have just discovered that the rebound adjuster on my (seemingly problematic!)fox triad (specialized one) wont rotate at all and the blue lever clicks into propedal and open ok but just wobbles about in the locked position?
HELP !!
How old is it?
Just warranty it if it's newish.
Normal to have free play in locked out position, rebound knob maybe dirt under the propedal lever or another internal fault.
no not under warranty brought frame second hand!!
I had that on mine, put it down as dirt.
Shortly after all dampening was lost, and it went in to Mojo to be fixed sadly they never told me exactly what they did to it so never found out what was actually wrong.
Basically there is a little ball bearing on the end of the rebound meter/control rod that sometimes falls off and jams the rebound, full service and new meter rod needed.
