Rebound adjust on R...
[Closed] Rebound adjust on Rebas- Broken?
Right after realising that my rebound was all the way over at 'tortoise', I decided that the natural course of action to fix this would be the little red rebound adjustment knob... when I put it in and started turning it however; all that seemed to be happening is the 'allen key' head thing rubbing around inside the fork leg. In essence IT DIDN'T WORK!!
Could someone explain why this happened just now, as it had worked on all other occasions?
Quite irritating as I was looking forward to enjoying my the next couple of weeks that I have off ๐Ÿ™
Posted : 07/08/2011 9:47 pm
anyone?
Posted : 07/08/2011 10:08 pm
try a new allen key with some fresh edges on it.
Posted : 07/08/2011 10:09 pm
is it pushed all the way in?
Posted : 07/08/2011 10:14 pm
pretty much.
Youll probably need to use the long section of the key to engage with the rebound adjuster shaft so you might need to use something on the shorter section to get some leverage.
Posted : 07/08/2011 10:15 pm
