Reba vibrations.
[Closed] Reba vibrations.
Got a set of 2010 Reba race on my Giant Anthem set at 100mm still. Under heavy braking getting quite a bit of vibration coming through them. Running 165mm Hope discs. Headset tight, QR tight. First forks ever had this happen on, any thoughts be appreciated.
Ta.
Posted : 28/01/2011 11:37 am
It's most probably a brake problem. It's possible that the for bushes are a tad slack too (Stick your finger between the fork arch and the stanchion and rock the bike with front brake on. You might feel some play in there, like a headset)
But to be fair, you won't really feel that when riding. I'd check the brakes first. Do you have another brake you could swap over to check for instance?
Posted : 28/01/2011 11:45 am
Thanks for that info, will try your sugestions and see what happens.
Posted : 28/01/2011 11:58 am
tray sanding the discs. Uneven deposits of pad on the disc is the likely culprit
Posted : 28/01/2011 11:59 am
