I've got 100mm Reba Solo Air shocks (single pressure valve)
Currently running at 120psi, as per my 80ish KG should be.
However, now its wintertime I'm mainly using it as a road bike with the forks locked out. There is still some play even with the forks locked out, which I believe is perfectly normal.
If I'm going to be using them exclusively locked out on the road, will increasing the pressure to the max of 200 psi firm them up in the locked out position and decrease any movement, or is it only for when they are in suspension mode?
And is this something I shouldn't do for any reason?
Thanks
Posted : 01/12/2014 5:30 pm
